Sport button problem
taz21
Post by taz21 » Fri Dec 14, 2007 9:16 pm
Hi can any one help please, when i press my sport button on the steering wheel,the seats inflate,but the exhaust sound doesnt change?
No exhaust valve mods have been done. :(
reevesroadster
RE: Sport button problem
Post by reevesroadster » Fri Dec 14, 2007 9:21 pm
did you press the "start" button :biggrin3: :biggrin3:
Everyone is unique, just like you and me.
Pig
Post by Pig » Sat Dec 15, 2007 11:04 am
Trip to the dealer i would say.
RS 57 FOR
t_urbo
Post by t_urbo » Sat Dec 15, 2007 11:07 am
At idle activate sport button and look to see if the flaps are open, if they are then its working.
Ozrs4
Post by Ozrs4 » Sat Dec 15, 2007 12:08 pm
and have a quick check to see if the vacuum line has became detached accidentally!
2007 RS4 B7 - Phantom black saloon
taz21
Re: RE: Sport button problem
Post by taz21 » Sat Dec 15, 2007 11:37 pm
t_urbo wrote:At idle activate sport button and look to see if the flaps are open, if they are then its working.
Thanks for the reply!
But how and were do i need to look to see if the flaps are opening?
taz21
Post by taz21 » Sat Dec 15, 2007 11:39 pm
Ozrs4 wrote:and have a quick check to see if the vacuum line has became detached accidentally!
Thanks mate!
please can you tell me were the vacum pipe is?
t_urbo
RE: Re: RE: Sport button problem
Post by t_urbo » Sat Dec 15, 2007 11:48 pm
The flaps are located in the tail pipes, they are a few inches back from the end of the exhaust.
When the sport button is off you will see that one of the tails pipes on each side is shut, when you activate the sport button the flap opens and you will see up both tail pipes on both sides.
Ozrs4
Post by Ozrs4 » Sun Dec 16, 2007 2:06 am
and for the vacuum line, lie on the ground and look up where the valve attenuators are (the round thing next the the pipe) and there is a black rubber hose coming out from that- connecting to the small 90 degree white plastic adaptors which then connect to the smaller green rubber hoses (same on both left and right side). Hope that make sense! Cheers.
Nickm
Post by Nickm » Sun Dec 16, 2007 8:43 am
At low rpms you will notice little difference. In sport mode the flaps open below 1000rpm (I think) and then re-open at 5,550 (I think) - so apart from looking, you need to go and give it some stick.... or listen very carefully without touching the throttle.
taz21
Post by taz21 » Sun Dec 16, 2007 7:29 pm
Thank you TURBO, OZRS4 AND NICKM,all for your help.
problem sorted,the had been standing for a while so the flaps got a little stuck,when i checked the flaps they were open,but only half closeing when the sport botton was being switched of,hence couldnt hear the sound changing.
Thanks all again
Lots of good people on here!!
taz21
Post by taz21 » Sun Dec 16, 2007 7:33 pm
problem sorted,the car had been standing for a while so the flaps got a little stuck,when i checked the flaps they were open,but only half closeing when the sport botton was being switched of,hence couldnt hear the sound changing.
Thanks all again
RussianM3_dude
Post by RussianM3_dude » Sun Dec 16, 2007 9:22 pm
taz21 wrote:Lots of good people on here!!
Thanks dude.
Users browsing this forum: Google [Bot] and 321 guests
