Page 1 of 3
Got the new tyres on....
Posted: Thu Nov 29, 2007 10:04 am
by tartan_rob
Well had 4x goodyear F1 Asymmetric fitted yesterday. 275/30/19 Y96.
http://eu.goodyear.com/uk_en/tires/repo ... /index.jsp
I have only done about 100miles so not pushing them but I immediately noticed they are much quieter than the PS2, slightly harder ride due to lower profile (for me that is good) and the turn-in is much more precise. The grip seems excellent too - although I have not pushed them at all but they feel much more planted under the same driving conditions. And the best bit, £152 a tyre delivered....
I'll post some pics over the weekend but I fear this tyre will push the michelin off its high perch.
Rob
RE: Got the new tyres on....
Posted: Thu Nov 29, 2007 10:08 am
by MarkB
Sounds good. It'll be good if you report more after you get some more miles on them.
Slighty subjective as you've changed tyre size at the same time though.
Re: Got the new tyres on....
Posted: Thu Nov 29, 2007 12:09 pm
by alex_123_fra
Tartan_Rob wrote:Well had 4x goodyear F1 Asymmetric fitted yesterday. 275/30/19 Y96.
Rob
Rob, sounds good. I'd be interested to hear how they are when they have some more miles on. What prompted you to go for larger width? Will this help with grip?
Also, is there much rim protection with your new goodyears especially with the lower profile size?
RE: Re: Got the new tyres on....
Posted: Thu Nov 29, 2007 12:29 pm
by Ozrs4
Hi Rob, is this a replacement of the Goodyear F1 GS-D3? is it more expensive than F1 GS-D3? Please show us a close up photo, I'd like to see the sidewall and the rim protection. Does anyone agree the tread pattern is very similar to the Pirelli P-Zero Rosso?
Posted: Thu Nov 29, 2007 2:24 pm
by PetrolDave
Tartan_Rob wrote:And the best bit, £152 a tyre delivered....
Wow!!! That's a great price. That's £608 a set compared to the £940 a set I paid for the PS2s in June.
Where did you get them from?
Posted: Thu Nov 29, 2007 2:28 pm
by tartan_rob
Guys - I went upsize to drop the profile + reduce costs. The Asymmetric only comes in set sizes just now. The rim protection looks good, I damaged all my wheels with Michelin so I don't rate them at all for the rim protection.
They came from
www.tyrexpress.com. I'll get some photo's at the weekend.
Posted: Thu Nov 29, 2007 2:58 pm
by tartan_rob
Here are the obvious tyre options for the car.......
Posted: Thu Nov 29, 2007 3:01 pm
by tartan_rob
and the other two.
Posted: Thu Nov 29, 2007 3:04 pm
by pippyrips
Thats an outstanding price, i was about to order the verdestien Ssantas which came 2nd only to the new Goodyears however at this price these are very tempting. As mentioned above will the only difference be ride comfort and potentially more grip due to the change in size or are there other things to consider?
Posted: Thu Nov 29, 2007 3:10 pm
by tartan_rob
My speedo is about 1mph worse than before. I can live with that, I have roadangel for accurate speed measurements. And they are MUCH quieter, so from inside the car you hear more of the engine note.
Re: RE: Re: Got the new tyres on....
by alex_123_fra
Ozrs4 wrote:Hi Rob, is this a replacement of the Goodyear F1 GS-D3? is it more expensive than F1 GS-D3? Please show us a close up photo, I'd like to see the sidewall and the rim protection. Does anyone agree the tread pattern is very similar to the Pirelli P-Zero Rosso?
Just looking at the tyre express website, it seems the eagle F1 asymmetrics are £10 cheaper per tyre than the equivalent eagle F1 GSD-3. What is the difference between these 2 tyres, does anyone know?
Rob, according to a tyre size calculator site, your new tyre size is only marginally smaller in diameter and circumference than stock. Your speedo will apparently read only 2% too fast. That is well within the acceptable limits.
Posted: Thu Nov 29, 2007 4:19 pm
by P_G
Technically the F1 Assymetrics have been brought out to replace the GS-D3's as they are ceasing production of this tyre, even though it was a great tyre.
If the assymetrics are as cheap as you say Rob they are what will be going on my RS when I need them. Although 255 to 275 width is a fair jump in size, do the fit the rims OK? Any pics?
As said it will be interesting to hear your views once you have scrubbed them in better.
Posted: Thu Nov 29, 2007 5:44 pm
by pippyrips
Regarding the rim protection - won't the extra tyre width help as the tyres will protrude over the rim?
Posted: Thu Nov 29, 2007 6:27 pm
by audijohn
Yes it looks very much the same, and what sort of extra "Drag" will be there to pull down economy?.
RE: Re: RE: Re: Got the new tyres on....
Posted: Fri Nov 30, 2007 10:58 am
by tartan_rob
I'm not convinced the tread pattern looks the same but I suppose ultimately, in the theoretical world, there will only be 1 ultimate perfect tyre for all conditions.
