4GB SD Card for RNS-E - Valuemedia.co.uk
Posted: Wed Nov 07, 2007 4:45 pm
by dubbers
The Hama 4GB SD Card found (
http://www.valuemedia.co.uk/4Gb_sd_card.htm) works fine with the RNS-E after it's been formatted to FAT32 and 4096 byte blocks (arrived with 32K blocks). Costs about £30 after delivery (2 days for my order).
Hopefully saves someone a bit of time, as other vendors seem to have supply problems of the non-HC 4GB SD Cards judging by the two cancelled orders I had.
RE: 4GB SD Card for RNS-E - Valuemedia.co.uk
Posted: Wed Nov 07, 2007 11:16 pm
by Scoobysnack
is this an HC SD card, or a normal one ? Hopefully normal?
J
Re: RE: 4GB SD Card for RNS-E - Valuemedia.co.uk
Posted: Thu Nov 08, 2007 7:30 pm
by dubbers
Scoobysnack wrote:is this an HC SD card, or a normal one ? Hopefully normal?
J
A normal one, plain old SD Card (Rated at I think 133x)
Re: 4GB SD Card for RNS-E - Valuemedia.co.uk
Posted: Fri Nov 09, 2007 9:19 am
by oilman4345
dubbers wrote:The Hama 4GB SD Card found (
I have a 4gb card which I have given up on as it did not play in the car. (now use 2gb instead). How do you format the 4gb as you mention in your post, as I will try and re-format!
RE: Re: 4GB SD Card for RNS-E - Valuemedia.co.uk
Posted: Fri Nov 09, 2007 1:11 pm
by Daz
Why not just buy more 2Gb cards. You can get 3 x 2Gb for the price of a 4Gb.
http://www.mymemory.co.uk/memory/MyMemo ... e/Digital)
Posted: Fri Nov 09, 2007 1:30 pm
by PetrolDave
J
SDHC cards won't work in the RNS-E, only "normal" SD ones.
Posted: Fri Nov 09, 2007 2:30 pm
by bigh
Just seen this!
cheers dubbers very usefull.
Posted: Sat Nov 10, 2007 6:11 pm
by dubbers
oilman4345 wrote:dubbers wrote:The Hama 4GB SD Card found (
Just right click the SD card driver letter - Select format, choose options as shown.
It does take the RNS-E a while to load a 4GB card. In my case 600 songs takes about 2 minutes.
np Bigh - hope its useful
