Bad Fuel
Posted: Tue Oct 09, 2007 3:35 pm
by Jabbafumi
Recently I was out in the sticks and filled up with dodgy fuel, the car went like crap afterwards and hasn't sorted it's self out since, I have filled up at least three times since, any ideas.
Posted: Tue Oct 09, 2007 5:40 pm
by alex_123_fra
If fed a lower ron fuel, the ECU will <beep> the timing and it will feel slower.
When back to normal 98-99 RON stuff, you should give it plenty of hard runs so that it re-adjusts. If it is still running badly, get it checked.
How "dodgy" was the fuel you used? You didn't use diesel did you?
Posted: Tue Oct 09, 2007 5:49 pm
by PetrolDave
I had a bad week after filling up with "premium 98" from the Tesco at Bicester. Cold starting was poor (often took 2 attempts, and running was rough and noticeably down on power.
A few tanks of V-Power, after letting the tank run almost dry (try carrying a can of V-Power with you and letting it actually run dry) sorted it out though.
Posted: Wed Oct 10, 2007 8:50 am
by Jabbafumi
When I spoke to Audi they said I should just disconnect the Battery and leave it for 5 minutes, this will reset the car, any comments.
