Page 1 of 2
RS4 0-60 Times
Posted: Fri Oct 05, 2007 3:42 pm
by t_urbo
Did some runs today using the VAG-Com Controller, not sure how accurate it is at speed measurement but its worth a look.
Im sure had it been cooler, running 100 Ron, never had Arnold sized passenger and some more driver abuse the figures would be better.
Car has JD Engineering remap.
Running on 97 Ron, 2/3 tank of fuel with passenger.
Total driver and passenger weight 180 Kg.
Air temp 23 C.
Control Module Part Number: 8E1 910 560 Component and/or Version: 4.2L V8/4V FSI ยช0080
Run 1
US Units
0 to 60 mph: 4.7 +- 0.72s
Run 2
US Units
0 to 60 mph: 4.9 +- 0.79s
Run 3
US Units
0 to 60 mph: 4.2 +- 0.77s
Run 4
US Units
0 to 60 mph: 4.5 +- 0.78s
Run 5
US Units
0 to 60 mph: 4.3 +- 0.71s
RE: RS4 0-60 Times
Posted: Fri Oct 05, 2007 6:34 pm
by audijohn
So the average of those runs is
4.52 secs
Pritty much what we expect yes.
RE: RS4 0-60 Times
Posted: Fri Oct 05, 2007 7:14 pm
by GardinerG
So as the Ruskie would say, it's quite slow then?
The 4.2/4.3 times surprised me though.
Re: RE: RS4 0-60 Times
Posted: Fri Oct 05, 2007 7:18 pm
by rs4v8
GardinerG wrote:So as the Ruskie would say, it's quite slow then?
Scalextric is quicker!!
Surprising indeed, didn't expect figures that low.
RE: Re: RE: RS4 0-60 Times
Posted: Fri Oct 05, 2007 7:59 pm
by rAudiguy
Hmmm not bad but have you driven the new deisel skodas???????
Re: RE: Re: RE: RS4 0-60 Times
Posted: Fri Oct 05, 2007 8:18 pm
by audijohn
Oooops, Simon may bite.................
Posted: Fri Oct 05, 2007 8:49 pm
by GardinerG
RE: Re: RE: Re: RE: RS4 0-60 Times
Posted: Fri Oct 05, 2007 10:58 pm
by sykotoy
Dude ...why would you do runs with a passenger???????????????????????
Posted: Sat Oct 06, 2007 8:31 am
by Terry1948
It was to see real world 0-60 times without abusing the car. I think that they are quite impressive
Re: RE: Re: RE: Re: RE: RS4 0-60 Times
Posted: Sat Oct 06, 2007 8:51 am
by t_urbo
sykotoy wrote:Dude ...why would you do runs with a passenger???????????????????????
Had no intentions of doing Acceleration runs, initially i went to Log Timing Retardation under load which had some surprising results. Then thought i would do a few runs just to see what sorts of times the RS4 could do.
Doing some runs tomorrow without passenger.
Posted: Sat Oct 06, 2007 10:12 am
by 55JWB
audijohn wrote:So the average of those runs is
4.52 secs
Car is mapped dont forget....
Posted: Sat Oct 06, 2007 10:13 am
by Mori
Please specify how you launch the car exactly (revs, clutch dump or slip etc.).
Posted: Sat Oct 06, 2007 4:08 pm
by t_urbo
Mori wrote:Please specify how you launch the car exactly (revs, clutch dump or slip etc.).
Not very well!
Anything over 6 k just causes the clutch to slip, one time i tried to dump the clutch at about 6k and the car didn't move, the revs went around to what looked like the time clock
Anything under 3.5k causes it to bog, the higher times are when this happened.
It seems dumping the clutch at about 4.5k is the best and i think the best time i got was when i had a bit of wheel spin which helped keep the revs up.
Posted: Sat Oct 06, 2007 4:14 pm
by t_urbo
55JWB wrote:audijohn wrote:So the average of those runs is
4.52 secs
The lower times surprised me actually.
The average time is irrelevant really as it changes depending on how many runs you do.
Im sure when i do some runs tomorrow without a passenger and a lower temp i will get some better figures.
Will do some 0-100 runs too.
Posted: Sat Oct 06, 2007 5:08 pm
by rAudiguy
How are you recording your times?
