Page 1 of 2
Can the Press Clutch to Start be Overridden?
Posted: Thu Oct 04, 2007 5:32 pm
by t_urbo
Is it possible to Override this pain in the arse function?
RE: Can the Press Clutch to Start be Overridden?
Posted: Thu Oct 04, 2007 5:47 pm
by rs4v8
wtf is it even required? agree totally, pain in the arse....
Posted: Thu Oct 04, 2007 5:56 pm
by t_urbo
It takes some loading off the starter motor and no doubt some Health and Safety Law plays or will play a part in it.
Re: RE: Can the Press Clutch to Start be Overridden?
Posted: Thu Oct 04, 2007 5:59 pm
by rs4v8
t_urbo wrote:It takes some loading off the starter motor and no doubt some Health and Safety Law plays or will play a part in it.
Didn't know this. The old dear always starts her golf with the clutch in but couldn't explain why she does it. I guess she just knows better!! :D
RE: Re: RE: Can the Press Clutch to Start be Overridden?
Posted: Thu Oct 04, 2007 7:09 pm
by PetrolDave
There was a discussion about this a while back that got quite heated!
The root cause is the law suits against Audi in the US over 20 years ago when some dork tried to start his manual transmission car with it in gear and injured someone - the US courts blamed Audi instead of the incompetent driver. To avoid that happening they started making the starter motor only work when the clutch pedal is engaged on US model cars.
The benefit of reducing the load on the starter motor by dis-engaging the clutch and hence removing the load of the gearbox is especially noticeable on cold mornings when the gearbox oil is REALLY thick.
On the RS4 there's another good reason for pressing the clutch pedal ... try just tapping the "Start" button for a fraction of a second .....the starter motor will go through a complete start cycle until the engine starts taking several seconds, you DON'T need to hold the button down!
Posted: Thu Oct 04, 2007 7:15 pm
by rs4v8
I can't imagine how many garage doors would be wrecked without it then!!
:biggrin2:
Re: RE: Re: RE: Can the Press Clutch to Start be Overridden?
Posted: Thu Oct 04, 2007 7:37 pm
by t_urbo
PetrolDave wrote:There was a discussion about this a while back that got quite heated!
Cheers.
Soon you will have to fill out an on board Risk Assessment before the car will start, bloody joke. Still only got ourselves to blame.
Still would like to override it though if at all possible.
RE: Re: RE: Re: RE: Can the Press Clutch to Start be Overrid
Posted: Thu Oct 04, 2007 7:41 pm
by rs4v8
Aaaaaaaaargh don't mention the R.A. words on here!!! This is where I come to get away from that sh*te!!!!! :biggrin3:
Posted: Thu Oct 04, 2007 10:26 pm
by rAudiguy
RS4v8 from now on I would like a method statement to tell us all your intensions of the day. you know the sort of thing. ( firstly i will switch my computer on using the on button. once the machine has booted up i will enter my password...... bla bla.... I bloody hate method staements RA and anything to do with H&S I have to deal with them all day long and it drive me mad!! :evil:
:rant:
Posted: Fri Oct 05, 2007 8:01 am
by rs4v8
Agreed .... total BS...... :biggrin3:
Posted: Fri Oct 05, 2007 4:21 pm
by Love_iTT
I totaly agree with the RA stuff but when I was taught to drive, it was banged into me to depress the clutch for the two reasons above - safety, just in case it's been left in gear and it does indeed take the load of the engine. Mind you, that was in the days when most of the cars I would have driven would have been 6V, dynamo and side valve so the battery needed every chance it could get. :-) :-)
Graham
Posted: Fri Oct 05, 2007 6:24 pm
by GardinerG
I was just taught to waggle my knob. (the gearstick!). What did you think I meant?
Perverts the lot of you! :lol: ;-)
Posted: Mon Oct 08, 2007 9:05 am
by byron13
There is an adaptation channel in VAGCOM but not had ago yet.
http://wiki.ross-tech.com/index.php/Aud ... 8ED/8HE%29
Re: RE: Re: RE: Re: RE: Can the Press Clutch to Start be Ove
Posted: Mon Oct 08, 2007 11:54 am
by t_urbo
byron13 wrote:There is an adaptation channel in VAGCOM but not had ago yet.
Are you talking about the coding options 1? its adaptation +16.
If so ive tried this but when you put the new code it keeps reverting back to its original code for some reason, so i was not sure if this is the right adaptaion code.
RE: Re: RE: Re: RE: Re: RE: Can the Press Clutch to Start be
Posted: Mon Oct 08, 2007 1:49 pm
by PetrolDave
If you checkout the wiring diagrams (see the Bentley manuals) you'll see that no amount of coding with VAG-COM will change the fact that the clutch switch is wired in series with the starter button!
