Page 1 of 4
Discs & Pads Questions??
Posted: Tue Oct 02, 2007 10:57 am
by W8PMC
Car is going into the dealers tomorrow for new front Pads & possibly new Discs, as i'm getting vibration through the steering when braking hard, so i think i may have warped the front discs slightly in Germany a few weeks back
Will ask to see the discs in case it's just uneven pad wear that's causing the vibration as i've no intention of replacing the discs if not needed.
The brake warning lamp has not illuminated yet, but they do look well below 20% life left from a visual glance.
My 3 questions are? roughly what's the dealer cost for supply & fit of new front pads & discs?? & secondly does anyone know the biaise of front/rear braking?? I'd like to know roughly what life span rears will provide in relation to fronts? Lastly, what is the normal lifespan of front & rear pads & front & rear discs??
Cheers in advance.
RE: Discs & Pads Questions??
Posted: Tue Oct 02, 2007 11:14 am
by rs4v8
My fingers are crossed for you chief, hope it's not your discs as that is deffo gonna hurt your wallet..
Posted: Tue Oct 02, 2007 11:19 am
by t_urbo
Disc's do not warp, what actually happens is that a small amount of pad gets left behind on part of the disc and creates an uneven surface hence possible vibration, if you tracked the car then left the handbrake on after then you might get this.
Rear pad wear is down to rear loading.
Posted: Tue Oct 02, 2007 11:23 am
by rs4v8
Is that what happens? Hmm, maybe the discs I had on my VR6 golf had build-up then, strange though cos there was no actual build up of different coloured material on them
They were shaped almost like a pringle though!!
Posted: Tue Oct 02, 2007 11:41 am
by rAudiguy
Hi Paul,
my local dealer quoted me £440 inc vat and Labor to fit new disc and pads on the front and £300 inc vat and labor for the rears. wouldn't give me any idea on wear time though as down to driving style.
hope that helps mate
Jim
Re: RE: Discs & Pads Questions??
by t_urbo
rs4v8 wrote:Is that what happens? Hmm, maybe the discs I had on my VR6 golf had build-up then, strange though cos there was no actual build up of different coloured material on them
See here;-
http://www.stoptech.com/tech_info/wp_wa ... disk.shtml
Then go here;-
SPECSAVERS
RE: Re: RE: Discs & Pads Questions??
Posted: Tue Oct 02, 2007 11:56 am
by hertfordshire1
I killed my discs after going to the ring too.
however i had told the dealer i was going there, so they said wear and tear = i paid.
if they are not aware of the track use, claim normal driving and demand warranty work..
also get the brake fluid checked, mine bolied and was useless with the new discs and pads.
my pads were £300 and the discs £600 ish from memory..
my second set were also shagged after my second ring trip and I am to get these replaced FOC is mentioned above.
Steve
Posted: Tue Oct 02, 2007 12:00 pm
by rs4v8
t_urbo wrote:rs4v8 wrote:Is that what happens? Hmm, maybe the discs I had on my VR6 golf had build-up then, strange though cos there was no actual build up of different coloured material on them
See here;-
Then go here;-
SPECSAVERS
Like I said, couldn't see any different coloured material on the discs but they were definately worn and were definately not as straight as they should have been.
See here;-
http://www.humourtransplant.com/get_one_now
Posted: Tue Oct 02, 2007 12:04 pm
by DavidT
If the discs are worn, then its wear & tear, regardless of where the car was used, surely ?
The 'warped discs' debate has been around for ever. They can and do 'warp/bend/whatever term you want to use', no matter what StopTech say on their website. Pick up on the discs is more common than 'warping' in high performance setups though, which the RS4/RS6 setup is.
Posted: Tue Oct 02, 2007 12:07 pm
by t_urbo
rs4v8 wrote:t_urbo wrote:rs4v8 wrote:Is that what happens? Hmm, maybe the discs I had on my VR6 golf had build-up then, strange though cos there was no actual build up of different coloured material on them
See here;-
Then go here;-
SPECSAVERS
See here;-
Link not working
Not alot is straight these days
Posted: Tue Oct 02, 2007 12:08 pm
by rs4v8
Thanks DavidT...
Re: RE: Re: RE: Discs & Pads Questions??
Posted: Tue Oct 02, 2007 12:12 pm
by t_urbo
DavidT wrote:If the discs are worn, then its wear & tear, regardless of where the car was used, surely ?
Stoptech's not the only one.
It seems to me that there are plenty that will say they do warp but then again they would because their trying to sell the bloody things.
Posted: Tue Oct 02, 2007 12:15 pm
by rs4v8
See here;-
Link not working
Em, no. read the link properly!!
Posted: Tue Oct 02, 2007 12:19 pm
by t_urbo
Surely you can do better!
Posted: Tue Oct 02, 2007 12:25 pm
by rs4v8
Probably, but you didn't get it first time and that tells me I don't have to.....
Sorry chief, just pulling your leg, ok?
