Gearbox Issues
Posted: Wed Apr 04, 2007 9:27 pm
by DuncanMac
Having some issues with the RS in heavy traffic and when it gets hot.... Car has a reluctance to go into 1st... goes in but with a bit of shove and bucket of bricks like entry! Any ideas?
Its going in for a service in a few weeks (10k) and wil get them to have a look and do the TMC as well. Have also heard there is new ecu software out?
Apart from that.... it just gets better and never stops to make me smile ;-)
Posted: Thu Apr 05, 2007 7:41 am
by djcevo
Having exactly the same issue ref getting it in 1st when hot, due into Audi next tues for some parts to be fitted, it went in last week and they agreed there was an issue... When I find out what it is I will let you know
Posted: Thu Apr 05, 2007 8:17 am
by simple1
Have not had the sat in traffic issue but have had a problem when coming off the motorway after a lengthy period, the gearbox will allow you to come out of sixth but then bulks when trying to select any other gear. I tried to go into 5th and 4th, and it felt tike I was trying to select between the gates. I mentioned it to service dept and they could not replicate it, but suggested changing the oil as the problem gets worse when hot.
Posted: Thu Apr 05, 2007 1:03 pm
by DuncanMac
djcevo wrote:Having exactly the same issue ref getting it in 1st when hot, due into Audi next tues for some parts to be fitted, it went in last week and they agreed there was an issue... When I find out what it is I will let you know
Cheers... I beleive I use the same dealer as you so hopefully we will be able to sort something out! appreciate your help!
Posted: Thu Apr 05, 2007 2:02 pm
by gw007
Probably not much use to you, but my first RS4 (bought July '06) had similar problems... had a right struggle to get it in gear sometimes.
But my current RS4 (bought Nov '06) hasnt had any problems like that so far, gear changes have been much easier and havent had any of the problems I noticed in the last one.
Not sure if its an issue relating to earlier models of the B7?
Posted: Thu Apr 05, 2007 4:27 pm
by DuncanMac
Cheers... Mine was one of the first around along with djcevo's and daz's... So I would suppose it could be an early batch issue... mine had the clutch issue that was replaced under warranty within the first month.
hey ho... off to the dealer we go...
Posted: Thu Apr 05, 2007 5:03 pm
by simple1
Was a question I was asked, did it feel like a clutch issue, they bled the clutch anyway just to be sure but no air in it...
Posted: Sun Apr 15, 2007 9:43 am
by MVW
I find the RS4 gearbox very notchy when cold, reasonable when at normal running temp and like what people sya here abit iffy when hot.
It would be interesting to see what Audi say about these faults, are they just a trade off for a gearbox capable of handling 420hp.........
Posted: Sun Apr 15, 2007 1:19 pm
by simple1
MVW wrote:I find the RS4 gearbox very notchy when cold, reasonable when at normal running temp and like what people sya here abit iffy when hot.
Wouldnt think so, a B5 box with the selector adjusted corectly is a bit notchy cold, and fine the rest of the time...............
Posted: Sun Apr 15, 2007 5:40 pm
by PetrolDave
There was a problem with one of the clutch pipes on early cars which caused difficulty with changing gear - maybe you've got the old pipe?
