ESP - off
Posted: Tue Apr 03, 2007 2:18 pm
by hertfordshire1
Anyone out there drive their cars with the stability software disabled?
Does it make the car more fun, or is it a recipe for disaster!!???
Steve
RE: ESP - off
Posted: Tue Apr 03, 2007 11:26 pm
by Golich
When I demo'd the Avant I switched ESP off to see if it donuts any easier than the B5. It seemed much the same.
Warning don't try that unless the road is very greasy and you have loads and I MEAN loads of space. It can do some seriously wide radius circles VERY VERY quickly. BIG wet slippery car park required!!!
RE: ESP - off
Posted: Wed Apr 04, 2007 10:46 am
by Mikeyboy
Do you mean fully off?
I turn the traction control off pretty regularly, it saves the brakes on hard runs and most importantly kills most of the understeer. Doesn't allow you to get back end out but then its 4wd so its unlikely anyway.
fully off I've not been brave enough to try yet but may give it a go on the first track day of the year.
RE: ESP - off
Posted: Wed Apr 04, 2007 11:35 am
by fx2
I never ever have the traction control on, it already kills the quick gear changes. Full of is a bit tricky at the beginning, i'v done at least 4-5 spins(lost control in a corner) in the city, at night, on empty roads. On the track the ESP full off is a must for maximum fun
You can get quiet nice drifts for a 4wd.
RE: ESP - off
Posted: Wed Apr 04, 2007 9:17 pm
by Golich
What do you mean fully off? Can it be switched off in various degrees? I was able to get a partial donut at a wide junction by just hitting the switch once. I thought at the time the front end pulled more than my B5 would have which confused me as I was expecting more rear end power bias and I got a bit of larger radius 180 turn than I did on my b5 when I took it back to the same spot. But then I know how to brake the back end out on the B5. But I'm pretty sure the traction control wasn't interfering as I got power perhaps not all the power I did see to loose grip quite easily then gain grip part way through the 180. Hhmm now you have me thinking. Difficult to be certain from just one attempt what the car was doing or not?
Re: RE: ESP - off
Posted: Thu Apr 05, 2007 8:29 am
by hertfordshire1
fx2 wrote:i'v done at least 4-5 spins(lost control in a corner) in the city
Feck that!!!!
I know with the system engaged, quick getaways and shifts into second seem to prevoke a noticable dip in power, must be the TC kicking in and stopping warp drive......
Are there stages of TC?
on - partially on - fully off?
RE: Re: RE: ESP - off
Posted: Thu Apr 05, 2007 8:36 am
by simple1
If you push the ESP button, the light comes up on dash but system is still fully active although with lower limits, you need to push and hold ESP button for 5 seconds to fully disengage the system. This turns all driver aids off completely. Had one go at driving with this off, at Silverstone, and car is a handful, drifts nicely but when it breaks away, unless you have lightening quick reactions, it gets out of order very quickly.........
Posted: Thu Apr 05, 2007 8:44 am
by hamski
I'm almost scared and excited at the same time...like when you put your hand in a fire to see how hot it is (as a kid of course). need to find a big carpark
Posted: Thu Apr 05, 2007 9:10 am
by fx2
The thing that amazed me most was, that i was able to do a full burnout, front wheels standing completly still and the back ones burning at 8000 rpm
Had to cheat a bit though and got the car into the position on a slightly wet track and with the handbrake, still a very interesting 4wd, that would have been impossible with the Impreza.
Posted: Thu Apr 05, 2007 4:11 pm
by Adam
the name fx2 is burned into my memory should I ever wish to buy a used RS4
Posted: Thu Apr 05, 2007 5:25 pm
by Mikeyboy
Blimey Golich et al RTFM gentlemen, RTFM.
Posted: Thu Apr 05, 2007 10:35 pm
by flashyg
Good new for the b7 I'm liking it!
Shpin that funky music, wide boy.
Shpin shpin shpin...........
Posted: Fri Apr 06, 2007 10:27 am
by fx2
Adam wrote:the name fx2 is burned into my memory should I ever wish to buy a used RS4
The car is made for great driving!
Posted: Fri Apr 06, 2007 11:46 am
by Nige_RS4
Who RTFM on a test drive???
