Page 1 of 2
Don't ignore your tyre pressure warning
Posted: Mon Mar 19, 2007 11:03 am
by Andyuk911
Well., started the car and bing bong tyre pressure warning .... check round the car and all seemed in order ... out with the guage ... left rear 5lbs down ... so as I rolled slowing bcakwards my son spots a screw dead centre in the tyre.
Off to Kwick Fit on Sunday 2.00pm ...
Point to note .. Monitor ...
Oh and this was free ??
RE: Don
Posted: Mon Mar 19, 2007 1:51 pm
by Golich
Yes the pressure monitors are a great idea. Over the years with ultra low profile tyres I've found on occasion my tyre pressures to be low but all looked ok. You like to know about low presssure before you pounce into a corner!!!
OOo that sprint blue looks bonny...
Why does that colour look so bloody different on other models so much so that I didn't want to take the risk when ordering my RS4 and I went for the safer bet - Red. Mind you, the order form still has sprint blue and the salesman hasn't replied to my email querying the colour? Lucky dip!
Re: RE: Don
Posted: Mon Mar 19, 2007 2:19 pm
by bobjebb
Golich wrote:Lucky dip!
...As long as you dont get half and half...
So was that tyre repaired OK?
Posted: Mon Mar 19, 2007 2:21 pm
by hugy
Hi Andy911.
Did they scratch the alloy wheel while working on it.I find tyre centres in general are a little careless unless you stand over them,watching.I am thinking of buying a set of BBS CK wheels in anthracite finish.Do you know if I can use my original tyre pressure sensors?
Posted: Mon Mar 19, 2007 2:47 pm
by Andyuk911
hugy,
they were careful .. however the correct procedure is this with tape ..
The TM should work ok, whatever the alloy
Posted: Mon Mar 19, 2007 2:56 pm
by david7m
Does that tape not get trapped?
Posted: Mon Mar 19, 2007 3:02 pm
by SimonS4MTM
hugy wrote:Do you know if I can use my original tyre pressure sensors?
You may need different valves to mount the sensors on unless the wheel profile is similar.
The sensor bolts to the back of the valve and there are different valves for different wheels. The valves come in different lengths and fixing holes at different angles to suit most wheel types.
Posted: Tue Mar 20, 2007 7:59 am
by GlynRS2
How annoying is that!
Glad that the pressure sensors work well though.
Posted: Tue Mar 20, 2007 1:47 pm
by hugy
Thanks andy 911.I have just found out the bbs ck wheels will not fit!
Posted: Tue Mar 20, 2007 8:55 pm
by simple1
Mine bing bong from time to time, check them anf there is no drop in pressure, turns out to be part of the dis fault for which my dash was changed along with low oil warning.
Posted: Tue Mar 20, 2007 10:05 pm
by SteveH
I've never seen anyone use tape like that Vauxhall alloy picture... I'm paranoid that my spotless alloys will get buggered when I get new rears next month :cry: Sadly, I'd pay say an extra £20 for extra time care and attention spent on each alloy.
Posted: Wed Mar 21, 2007 11:11 am
by andypandy
what are the tyre pressures on the rs4 b7,mine has no sticker
Posted: Wed Mar 21, 2007 3:18 pm
by simple1
I run mine at 36 front and 33 rear, not sure how that compares to recommended but seems to suit my car and driving style.
Posted: Thu Mar 22, 2007 2:08 pm
by Mikeyboy
supposed to be 38 and 35 for the 19" wheels. any less will give you decent frip once warmed up but will be running about 10% less efficietly at Simple's pressures
Posted: Thu Mar 22, 2007 9:49 pm
by simple1
run them at 38 and 35 and you will have damaged tyres, wheels and sore back on the country roads I use........... my car works fine at those pressures, but its a personal choice for the feeling and feedback the car gives.
