Dies in 2nd gear
Posted: Fri May 05, 2006 4:11 pm
by Davey_B
A couple of times when I've been pulling away quite hard and changed into 2nd gear and accelerated hard again, the engine dies for for a moment before pulling again. At first I though it was the traction control, but the light on the dash doesn't come on so I don't think it is.
Anyone else has the same problem?
While I'm having a moan, does anyone elses run as rough as a bears arse when its cold.
I know the dealers were supposed to change the spark plugs at PDI, I'm thinking mine might have slipped through and the original plugs are the problem. Thoughts?
RE: Dies in 2nd gear
Posted: Fri May 05, 2006 4:18 pm
by SimonS4MTM
I changed mine at the weekend, the plug closest to the front of the engine on the passenger side can be difficult to get to, i found that this one looked as though it had not been changed since new. If in doubt, do them yourself or make sure that you always see the old parts.
Posted: Fri May 05, 2006 4:33 pm
by Davey_B
Bit loath to do it myself if it should have been done at PDI and I don't want the dealer shouting void warranty at me if I change the plugs myself.
Posted: Fri May 05, 2006 4:37 pm
by djcevo
Davey B,
Regarding the dieing issue - mine does the same, however when I turn the t/c ESP off it's fine so it is to do with that so no need to worry.
Posted: Fri May 05, 2006 4:44 pm
by SimonS4MTM
Sorry, just noticed it is a B7 not B5
Posted: Fri May 05, 2006 5:07 pm
by Davey_B
djcevo wrote:Davey B,
Not subtle is it? It's like the engine has stalled.
Posted: Fri May 05, 2006 7:31 pm
by rs666
Ask them to change them and show you the old ones to prove its been done. Get straight into your dealership, you paid a lot of money for it, get it sorted.
Posted: Mon May 08, 2006 9:38 am
by jonp
Mine does the same. I have only noticed it a couple of times. The B5 didn't do it, so it shouldn't be the ESP. I will let the dealer know
JonP
dies in 2nd gear
Posted: Thu May 11, 2006 11:22 am
by RedBaron
mine dies in first,(when you floor it ) second, and third when changing up quickly from high revs.Turning off the ESP stops it .
Went to the dealers and they test drove it, booked it into be checked out for a day on the computer and said will call audi with a "dis" report and see if they are aware of the problem and have an upgrade for the management system or the t/c system . couldn't have been more helpful or appologetic.
RE: dies in 2nd gear
Posted: Thu May 11, 2006 7:35 pm
by Riz_RS4
Im not sure if this is a similar problem to which the Golf R32`s suffered... seems to sound the same to me..... the engines power delivery hesistates under load when pulling away etc... a new ecu mapping cured the problem and transformed the car! It took alot of us on TSN to log this fault with VW before the UK`s master techie at HQ investigated the problem... VW Germany knew so a new mapping was made.
Hope mine doesnt have this problem :(
Riz
Dies in 2nd gear
Posted: Fri May 19, 2006 7:28 pm
by nuthintoprove
Mine too, give her the holley from 2000 revs in 2nd or third and she stalls momentarily. 2 outa 3 times. :( By the way, My dealer, Agnew Belfast, told me the engines were bench tested and she dosnt need run in, but im not taking any chances.
Posted: Fri May 19, 2006 7:55 pm
by startrek
I've not had any of the symptoms you guys are talking about so sounds a bit strange and I do boot mine quite alot?
Re: Dies in 2nd gear
Posted: Sat May 20, 2006 7:27 am
by simple1
nuthintoprove wrote: :( By the way, My dealer, Agnew Belfast, told me the engines were bench tested and she dosnt need run in, but im not taking any chances.
Wouldn't trust a word they say.......... Agnews are the biggest shower I have ever come across. I bought my B5 from them and they were so inept it was a laugh....
RE: Re: Dies in 2nd gear
Posted: Sat May 20, 2006 9:38 am
by lightning
where u boys from?? im from moira!
