Aircon not working
Posted: Sat Aug 17, 2024 11:37 pm
by Frazz82
The aircon doesn't work it holds the gas and the fuses are ok so while I had the front end off I took a punt an changed the aircon pressure switch but it didn't work.
So before I look at the aircon pump is there anything else it could be ?.
Re: Aircon not working
Posted: Sun Sep 01, 2024 1:24 pm
by m5killer
Receiver drier I have the same problem as well as a leaking pipe that goes to the above
Posted: Tue Dec 17, 2024 9:28 pm
by Kanerrad
I had a similar issue a couple of months ago and it was found to be the main fan motor that was the issue. Once replaced, everything worked as it should
