Sway Bars suspension + DRC delete
Posted: Tue Jul 23, 2024 10:36 pm
Having installed KW Coilover suspension V1's, I'm looking into uprated Sway Bars in order to compensate for the removal of the factory DRC setup.
I believe the general consensus from the likes of 034 Motorsport is to stick with the OEM Sway bar at the front (albeit renewing the bushes), and replace the OEM rear Sway Bar setup with the 034 version.
Hopefully, their uprated 034 rear sway bar should serve to improve the ride quality, whilst being effective at combating body roll when combined with KW V1 coilovers.
That being said - has anyone had any experience of the above setup?
Aware H&R also do a Sway Bar Front + Rear setup, but have heard the ride quality suffers on normal roads (something I would rather avoid)
Also, in any case - can someone please provide the Torque specs for the Factory bolts for the Front and Rear Sway Bars ?
After replacing the leaky Factory DRC shocks .. I had another surprise when I recently went to replace the Fuel Filter:
