EPC Light EML Light 614 Relay Fuel Pump Relay
Posted: Fri May 17, 2024 1:47 pm
After 6 years of trouble free motoring, my 2007 RS4 Avant decided to have a little wobble today.
Laboured start (normally fires in about 3 cranks), then it started, lumpy and the EPC light was on. The EPC has never been on before.
Drove it carefully and car would go from running fine, to misfiring a bit. Then the EML light came on.
Car then stalled; and was difficult to start, however when it did start, it ran absolutely fine.
Got home, ignition off, ignition on and all was well again ...
I did do a quick scan with a cheap scanner to look for clues and got the following
P0458
P2009
P2257
P0414
P0031
P0037
P129C
P0051
P0057
Lots of Googling seems to point to the relays, which i will try first to eliminate if nothing else.
I understand that the relays are located under the ECU and that the offending one is the Fuel Pump 614 (now superseded by 644), but it is good practise to change them all out seeing as getting to the relays is a bit of PITA, including the removal of a wiper arm.
My question is ... apparently there are also relays (including 614) located in the interior of the cabin by the UK Drivers side "knee" area...
I just want to ensure that I am indeed changing out the right relays, as the internet seems to be a little conflicting.
As ever, any guidance would be much appreciated.
Thank you
P0458
P2009
P2257
P0414
P0031
P0037
P129C
P0051
P0057
Thank you
