Front Caliper Mounting Bolt - Part number?
Posted: Wed Apr 03, 2024 5:56 pm
by lugars4
Audi are not recognising this bolt, saying (not applicable to vehicle). Yet it’s definitely there! I want to replace them when doing discs.
Any ideas?
Re: Front Caliper Mounting Bolt - Part number?
Posted: Wed Apr 03, 2024 6:04 pm
by stuartbarriskell
Does the schematic give you thread pitch and shank length of bolt ?
I'd just order a like for like from pro-bolt, Westfield Fasteners or the likes..
Sent from my SM-S918B using Tapatalk
Posted: Wed Apr 03, 2024 11:23 pm
by lugars4
No, it’s not listed at all. Would like to order them up before I strip it.
Posted: Wed Apr 03, 2024 11:34 pm
by stuartbarriskell
Crazy they said it wasn't listed. The bolt looks to go thru the body of the Caliper and into the carrier ?
I'd guess it's an m10 x 1.25 or 1.5 or an M12 x 1.5.
I've a pair of B8 Calipers sitting on my bench,
which isn't much help.
I'll actually nip out for a look..
Not much help I'm afraid, but if those are bolts which secure the Caliper, thru the Carrier I'd say they might be a bit heavier, mine are M14 x 1.5 as per images.
Those schematics are generally not to scale in a lot of cases
Posted: Wed Apr 03, 2024 11:54 pm
by lugars4
Yeh not ideal. Also looking online same problem.
https://www.lllparts.co.uk/catalogs/aud ... 615/615050
From the workshop manual, clearly shows them, item 9.
Posted: Thu Apr 04, 2024 12:07 am
by stuartbarriskell
They'll be quite heavy, man. M12/M14. I've emailed A for Audi and asked a question. I will send this one too.
Just what I said. No15 on that first slide looks puny compared to this shot..
Posted: Thu Apr 04, 2024 8:22 am
by stuartbarriskell
There you go lugars, as I had suspected, it's a fairly beefy bolt...
any idea of length?
Hi Stuart
It is correct that Audi do not list or supply this bolt, although Porsche list them for their cars. They are all M12x1.5 but have different lengths.
If you know the length required, I could give you a part number.
Paul
Posted: Thu Apr 04, 2024 10:41 am
by lugars4
Thanks for the additional info!
Talking to Audi again today, they can supply the bolt #3 in the last diagram i posted above.
So must be they intend for you to take the caliper and carrier off in one, per your photos.
I had seen videos of the smaller bolts holding the caliper to the bracket being seperated for disc change, will remove the carrier and have ordered the bolts (they hold them in stock, so must be a common part), will post PN once ive collected them.
Posted: Thu Apr 04, 2024 12:04 pm
by stuartbarriskell
Ah good man, so nothing needed from moi then ?
