Loose Gearshift
Posted: Mon Jun 19, 2023 1:05 pm
by highrise
Hi,
My RS4 has 130k and the gear shift has quite a bit of play in it. It can be hard to be accurate with gear selection. I've also driven other RS4's and the selection is much tighter.
I know there is a ball socket that can wear and cause the issue.
Has anyone had this issue and fixed it without replacing the entire unit (which I think it part number: 8E0711025QS)
Many thanks
Loose Gearshift
Posted: Mon Jun 19, 2023 11:48 pm
by SeikoKid
replace the ball socket part as you have asked - i had this with 1st / 2nd gear
Check with audi the part number
I also fitted a JHM short shift to mine - Now that makes a difference !
Re: Loose Gearshift
Posted: Tue Jun 20, 2023 10:55 am
by highrise
Thanks for your response.
Where did you get the rebuild kit?
Would this work?
https://www.ebay.co.uk/itm/304856215780 ... BM5JPNg5ti
Many thanks
Re: Loose Gearshift
Posted: Fri Jun 23, 2023 7:11 am
by SeikoKid
my mechanic got if from GSF i think
Defo not from ebay !
Re: Loose Gearshift
Posted: Thu Jun 29, 2023 1:37 pm
by highrise
Cheers.
I might go with the JHM kit but want it as close to stock as possible.
Re: Loose Gearshift
Posted: Thu Jun 29, 2023 10:50 pm
by SeikoKid
Short shift is only the gear stick selecting mech in the centre console of the car. You can get other parts for it that attached to the gearbox but i didn’t see the point for a road car - the upgrade is enough and just takes a lot of travel out of your gear changes
Re: Loose Gearshift
Posted: Fri Jun 30, 2023 9:24 am
by highrise
Thanks, that's good to hear.
I was also thinking about replacing the (8D0798151) part, see image below.
I've heard it wears and makes a difference.
Does anyone know how easy this is to replace, i.e. access etc?
Loose Gearshift
Posted: Thu Jul 06, 2023 11:12 pm
by SeikoKid
My mechanic replaced that when i had the prop shaft repaired ( feltham prop repairs ) they fitted a cosworth knuckle as mentioned it’s the only one that is strong enough ?? Certainly took the hum out of my car when above 40mph
The audi design was a bit crap and unrepairable
That gear ball joint has made my gearbox excellent again. 1st / 2nd was sometimes a no go and had to hit reverse first and then 1st
