B7 RS4 new pistons!!
Posted: Fri Jan 06, 2023 12:02 am
Hi
Has anyone on the forum extended the block bore diameter by .5 mm bringing the bore out to 85mm, if so did you find a company supplying a 85mm forged piston & 92.8 mm rod kit that works.
I need to bring the bore out slightly as my Ive had some mild scoring within the bores.
Trying to firstly go this route rather than sleeves, want to do this to keep the Alusil finish, Audi have spent alot of R&D on such a finish to throw cast sleeves in would be the second option if I cannot source the mentioned spec pistons required.
A word of caution, if you happen to own a B7 RS4 with high mileage and you don't know when it's oil pump was last changed I would recommend getting a new one fitted to avoid a catastrophic engine failure with very little warning!
Cheers.
Cheers.
