Misfire under high engine load - help!
Posted: Mon Dec 20, 2021 7:29 pm
by Toymad
I've been chasing a misfire for about a year, and two different garages haven't been able to sort it and the local rolling road flat out refused to look at an RS4:( Any input gladly received, these are the symptoms:
Misfire under high engine load, ie 6k revs and booting it in 3rd, will deliver power for ~1-2 seconds and then stutter. Off the gas (eg to change gear) and then back on the power and it will be fine for another 1-2 seconds before misfiring again.
Variations: Sometimes will misfire at lower revs, eg lugging in 4th at ~4.5k revs. Raising revs gently to the red line doesn't result in a misfire. Seems to be better after a really good blat and worse after sitting on cruise at 60mph for an hour or whatever.
Possibly related, possibly not: Idles and runs a bit rough and cranks longer before it starts when its cold.
Changed fuel filter
Changes spark plugs
Inspected fuel tank for crud, blockages.
Carbon clean approx 10k miles ago
Changed some vacuum thingie, sorry can't remember what the garage said it was.
It really feels like fuel starvation to me, anyone else had these symptoms?
Re: Misfire under high engine load - help!
Posted: Mon Dec 20, 2021 7:53 pm
by QuRace
It really feels like fuel starvation to me, ...
That's what I immediately thought, too: LPFP/HPFP. Did you check for any related codes?
Posted: Mon Dec 20, 2021 11:51 pm
by Toymad
It's not throwing any codes out, at least, none that my cheap code reader sees.
Posted: Tue Dec 21, 2021 9:28 am
by 12th
Fuel pumps? There are two.
Posted: Wed Dec 22, 2021 9:56 am
by Covkiller
Have you checked your coil packs?
Posted: Sun Mar 13, 2022 8:27 pm
by jack_hamlett
Did you find the problem in the end?
Posted: Wed Apr 30, 2025 11:25 pm
by TrevoRS4
This!!?
Posted: Thu May 15, 2025 1:05 pm
by rshales007
An old thread now, but RE Performance did a couple of videos on an RS4 with a similar sounding issue.
Part 1 :- https://www.youtube.com/watch?v=KwVihDuVwSs
Part 2 :- https://www.youtube.com/watch?v=CkX2RtNIbdU
Well worth watching.
