Oil cooler - ticking time bomb?
Posted: Tue Sep 14, 2021 11:31 pm
by otb123
Just bought a lovely example of a B7. Whilst it’s had the suspension, deflap and decoke done the oil cooler and pipes have yet to be touched.
Is it the case of they all go bad eventually and leak or do some last depending on how/where the cars are used?
Cheers.
Re: Oil cooler - ticking time bomb?
Posted: Thu Sep 16, 2021 12:27 am
by Shy Fly
Hi,
Likely it will fail sooner or later, issue is due to bi-metallic corrosion between the hose line couplings and the oil cooler, my B7 only done 38k miles and just replaced cooler with the excellent Forge product.
Posted: Thu Sep 30, 2021 9:44 am
by downhillmalins
If you change the pipes before they fully corrode and fail you can save and reuse the oil cooler, providing there are no leaks to it.
Posted: Mon Oct 18, 2021 11:20 pm
by DocMcc
Pipes are the expensive part
, the cooler can be got quite cheaply (for RS4 parts) on the aftermarket!
Posted: Fri Oct 22, 2021 9:56 am
by late_voyager
Just for info.
When you change pipes. Deburr the sharp edge on block. It cuts the oring on install.
Posted: Mon Oct 25, 2021 5:53 pm
by MIDZ
Recently installed new OEM hoses and a Radtec cooler. Greased the o-rings and they slide into the oil ports quite easily, impressed with the Radtec cooler which is good quality and a fraction of the OEM cooler cost.
Posted: Wed Nov 17, 2021 12:09 pm
by flylife2k
Yes definately do this upgrade as soon as you possibly can.. I didnt
Better to be proactive - the OEM ones do not really last unfortunately - Changed myself and as mentioned above good call with the Radtec radiator too
Quality piece of kit
