I have a 2008 RS 4 that I purchased recently, about 66k on the clock, with a JHM stainless cat back exhaust. It seems like someone has programmed the "Sport Mode" to always be on? The accelerator is super sensitive (especially in 1st gear), and the exhaust note is rather loud. When I press the S button I don't notice any difference.
I'm assuming that something was done in the programming. I have a VAG-COM, but I don't know where to look.
Is this probable, or am I off somewhere?
"Sport Mode" always on ??
JHM exhaust is not valved so even with the S button active or not, this will not make any difference in terms of the exhaust sound, do you know if you have catless DP’s or gutted piggies? Also the JHM exhaust comes with an Xpipe that is either res or non res, you will notice if its resonated if you see a resonator at the end of each pipe right before the curve starts for each rear muffler. If it doesnmt have these then yes, the system is quite loud…dubinpeace wrote:I have a 2008 RS 4 that I purchased recently, about 66k on the clock, with a JHM stainless cat back exhaust. It seems like someone has programmed the "Sport Mode" to always be on? The accelerator is super sensitive (especially in 1st gear), and the exhaust note is rather loud. When I press the S button I don't notice any difference.
S mode affects the way the throttle body reacts and makes it more sensitive, there is also a torque limiter for the first gears so what you are basically describing as “super sensitive” I assume is the fact that the car is “bucking” when you disengage the clutch and try to take off? If its this this will get resolved mainly with a tune and more seat time with the car .
Personally I’ve never read of anyone that has brought up the S function being permanently coded on, I can only think that the button itself is stuck but maybe it can be coded or uncoded but I’m not aware
Sent from my iPhone using Tapatalk Pro
Users browsing this forum: No registered users and 173 guests
