Forge Oil Cooler fitted
Re: Forge Oil Cooler fitted
12th, Did your garage manage to fabricate replacement pipes?
No, too corroded at pipe and cooler ends.
Sprint Blue B7 RS4 Saloon with MRC tweakery.
Yep, back to firing on all cylinders, thanks.
I would be interested to know what combination causes the issue. Because you can buy Audi replacement lines from LLL Parts and then get a radtec for around £700. But if the original lines will corrode with the radtec cooler it doesn’t make sense. Again, I’m assuming JHM lines also resolve the issue and could be used with radtec cooler. Although it appears they may lack quality control as per the above post. MDM technick is the cheapest Forge I could find at £924.78
Users browsing this forum: Google Adsense [Bot], psglas and 238 guests
