Intermittent starting issue
Posted: Fri Jun 04, 2021 2:47 am
by rs4dave
Hi Guys,
Have had a weird problem rear its ugly head recently. Details below:
-car will start 1st time every morning with no issues
-after driving the car and getting it up to normal operating temperature (oil temp 95C and above) the car will not restart once it has been shut off.
-the car will only restart after the oil temp has dropped into the min-high 80s
-with the ignition on and the clutch pedal in you can hear the starter relay click when the start button is pushed but the car does not turn over
I have done the following:
-replaced starter relays
-brand new starter motor installed
Has anyone else had the same issue ? If so what could it be?
thanks in advance
Dave
Re: Intermittent starting issue
Posted: Fri Jun 04, 2021 10:36 am
by coffey555
Is the heat shield installed next to the starter motor? My mate had the same problem, changed the starter, still did it.
Then he installed the heat shield (which was somehow missing) and that fixed the problem.
Posted: Fri Jun 04, 2021 11:03 am
by mikep99
Sounds similar to the issue I had.
I've come to the conclusion that when the under bonnet temps are high, the amps on the starter wire from the ECU drop for some unknown reason.
You can start it by shorting the starter wire with the positive terminal, there's a connector right next to it. See pics.
For the time being, I've put a relay on the starter circuit which lets the starter pull the power from the positive terminal when starting.
Not a had a problem since.... touch wood...
HTH
Mike
Posted: Sat Jun 05, 2021 12:08 am
by rs4dave
coffey555 wrote: ↑Fri Jun 04, 2021 10:36 am
Yes heat shield is installed
mikep99 wrote: ↑Fri Jun 04, 2021 11:03 am
HTH
Mike
Thanks Mike, I'll give that a shot
Posted: Sat Jun 05, 2021 9:15 am
by mikep99
Just make sure you short the side of the connector that goes to the starter, not the ECU
Mike
Sent from my M2007J17G using Tapatalk
Posted: Wed Jun 09, 2021 6:54 am
by Andyevo
Morning,
I had a similar issue a while ago, does it have an aftermarket alarm fitted by any chance?
Andy
Posted: Thu Jun 17, 2021 5:35 am
by rs4dave
Andyevo wrote: ↑Wed Jun 09, 2021 6:54 am
Morning,
Andy
Hey Andy,
Factory alarm, nothing aftermarket
Posted: Sun Jul 11, 2021 9:22 am
by rs4dave
Problem solved - replaced the starter cable from the plug at the battery terminals all the way to the starter solenoid, used extra heat sheilding and changed the location from where it was originally run near the headers. Have not had an issue since.
