Evening all. I have a B7 cab with 90k on. Its got a new Bosch battery, it's trickle charged throughout the week and I can heat the relays working. I used it a week last Friday and since then it's not started. It won't turn over. Could it be the starter motor ?? Im gonna get RAC to diagnose it I think.
Sent from my SM-N976B using Tapatalk
Non starter
- Silverfox42
Re: Non starter
Clutch switch fault could be the reason, if the sensor is stuck 'open' the start stop button won't work.
You could try removing/unplugging one or both. Worst that will happen (I think) is that you will lose cruise control and the car will start without the clutch being pressed down.
2017 RS6 Performance
Previous:
2006 RS4 B7 Cab, 2014 RS4 - Suzuka + a ton of toys, 2011 RS5, spec'd up + ABT exhaust, 2006 B7 RS4 'loon - 5 years of fun! 2006 Aston V8 Vantage, 2006 S4 Cab, 2005 S4 Avant, 2000 TT 225 Cab, 2001 2.5 A4 TDI Quattro, 2000 A4 1.8T Sport, 1996 2.6 80 Cab, 1997 A4 1.8 T Sport
Previous:
Re: Non starter
Changed 4 starter related relays, 2 batteries before I determined it was my starter. Have similar miles and started out as intermittent starting issued to eventual not starting. Pulled codes mentioned low voltage across the relays which make sense if your starter is bad. Good test is to check voltage drop when starting. If it's a new battery and the voltage drops while you crank the key, time for a new starter or maybe ground cable.
Starters are not too expensive, if you can DIY the job wasn't so bad also.
Sent from my Pixel 5 using Tapatalk
Re: Non starter
Thanks both.
Re: Non starter
A nice chap on ( illya? Apologies if I've spelt it wrong) here did a YouTube video on how to change a starter motor on a B7 RS4 .
Users browsing this forum: lugars4 and 155 guests
