Engine mount solenoid failure - causing a feeling like grumbly transmission?
Posted: Thu Apr 08, 2021 1:19 pm
hi all
My UK 57-plate B7 RS4 Avant with 92k miles has developed what feels like a slight judder, and I figured it might be transmission related. It's most notable when the car is cold, and when at low revs but above idle (2-3k), on steady throttle or when engine braking, and it just gives a grumbling judder like you're driving over rippled road surface. Sitting on cruise control at 40mph sometimes feels like the transmission is slipping ever so slightly - it feels like the revs are see-sawing ever so slightly but not enough to notice on the rev counter - just not steady and smooth.
I had a CV joint replaced late last year and noticed the tranny chatter after that, though it's quite possible that it had been present before; the garage who did that work said it might be a gearbox issue (car is on the original clutch AFAIK) and recommended a transmission specialist, who took a look at the car and pulled some DTCs (which to my shame I didn't think of doing before taking it to them). So I ran it through VCDS myself when I got it home - amongst the various codes caused by (I think) a flat battery some weeks ago, were 60 instances of:
005491 - Left Engine Mount Solenoid Valve (N144): Open Circuit
P1573 - 004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 60
Mileage: 141140 km <-- ie about 4,000 miles ago
Now if the active engine mounts reduce vibration, particularly when pressing on, would a duff mount - or an electrical problem to the solenoid valve - cause a fairly noticeable juddering at low and steady speeds?
The Right Engine Mount Solenoid Valve is also showing one instance of the same fault, but it's as of current mileage - so I wonder if it's a phantom...
Maybe I'll just get the car booked in to have both mounts replaced anyway - I'm supposing the labour to do both won't be 2x the labour to do one...
cheers
Ewan
Freeze Frame:
Fault Priority: 0
Fault Frequency: 60
cheers
Ewan
