Coil Pack connector removal tips?
Posted: Fri Feb 26, 2021 3:21 pm
by mikep99
Hi All,
Just went to replace my plugs but gave up after a while as one of the coil pack connectors was proving to be a pain to remove.
Now, I managed to loosen 3 of the 4 on the driver's side using the push towards coil pack, press on the clip till it clicks, and pull down method.
But the 3rd's being a PITA.
I tried a few times with a screwdriver in the clip and the connector clicked but still wouldn't move.
Didn't want to go overboard with the screwdriver so as not to snap anything.
Any tips?
Mike
Re: Coil Pack connector removal tips?
Posted: Sat Feb 27, 2021 2:41 am
by Kenny147
Breaking the connectors is not unusual as the plastic can become brittle due to heat and and age. The method I use, if they’re being difficult, is to push them in fully, then push the clip down and wiggle/pull at the same time. You might need to do it a few times before it works. If you push them in and hear a very faint click, you simply slide them out.
Good luck.
Posted: Sat Feb 27, 2021 10:41 am
by mikep99
Cheers Kenny,
I'll have another go at them this morning.
Found this video where he uses a pick so I'll try that as well.
https://www.youtube.com/watch?v=srBS3_Q82rY
ta
Mike
Posted: Sat Feb 27, 2021 1:18 pm
by mikep99
Success!
Using the method in the video above with the pick...
Worth giving it a go if your connectors are being stubborn
ta
Mike
Posted: Sat Feb 27, 2021 2:16 pm
by TrevoRS4
If you end up breaking them the part number is 4B0973724. There’s a lot on eBay.
Edit: well done I didn’t refresh my browser!
Posted: Sat Feb 27, 2021 2:30 pm
by Kenny147
TrevoRS4 wrote: ↑Sat Feb 27, 2021 2:16 pm
And do yourself a favour; get a good quality VAG electrical connector tool. If you have a quality one, it takes seconds to remove the individual junior power connectors from the housing and swap them over.
Posted: Sun Feb 28, 2021 1:50 pm
by James1984
I use a mini 90 degree pick on all these types of connector, makes them so much easier to remove
Posted: Sun Feb 28, 2021 2:39 pm
by mikep99
All done now and car starts with no warning lights etc.
Oil & filters done as well.
It's on blocks at the mo while my wheels are getting refurbed so I'll take it out for a spin towards the end of next week hopefully.
I used one of these to remove the coil packs:
https://www.ebay.co.uk/itm/T40039-Ignit ... SwkcVe1ae7
Well worth the small outlay IMO.
Cheers for the advice.
Mike
