Clarity on removing suspension assembly
Posted: Tue Jan 26, 2021 3:25 pm
My suspension needs a refresh. I have the Meyle HD suspension arms set and Bilstein B14's ready to fit. I'm also going to have new wheel bearings fitted while the front assembly is in pieces. The infamous pinch bolt fills me with dread and since I'll need a garage to replace the bearings, I plan to remove the entire assembly and give it to a garage. They can then use their proper tools to fit the arms to the hub, swap out the shocks and press in new bearings. I can then refit the same way I removed. Can anyone see any blockers to this plan?
In terms of what I need to do, I've got:
1) Drain, disconnect and cap off DRC
2) Remove caliper from hub
3) Remove disc from hub
4) Disconnect wheel speed sensor cable
5) Disconnect ARB drop link
6) Remove track rod connection
7) Unbolt lower arms at subframe end
Unbolt top mount
...which will allow the whole assembly to come out?
TIA!
TIA!
