Coilover conversion - labour time?
Posted: Mon Sep 28, 2020 12:09 pm
by TaPaKaH
Just a sanity check when talking to a garage:
When converting an RS4 B7 from a stock DRC to a coilover setup (KW V3, in particular), how many hours of labour shall the operation take?
Re: Coilover conversion - labour time?
Posted: Mon Sep 28, 2020 12:20 pm
by rs user
depends on a few things-to remove strut easily the front pinch bolt must come out-or here is extra time to remove the front upper arms from upper mount
to fit and set up i would budget for 3- 4 hrs with most give or take-and dependant on what method they use for existing rear spring removal
some may be a little quicker-some a little slower
Posted: Mon Sep 28, 2020 12:35 pm
by mikep99
Think I was billed for 5.5 / 6 hours labour for coilovers & all front arms replaced.
HTH
Mike
Sent from my PRA-LX1 using Tapatalk
Posted: Mon Sep 28, 2020 3:18 pm
by rs user
HTH
Mike
sounds fair-tops are almost a while you are there job maybe extra half hour a side max[again if pinch bolt isnt solid],lowers would add a bit of time too
Posted: Mon Sep 28, 2020 9:40 pm
by jamiej
mikep99 wrote:Think I was billed for 5.5 / 6 hours labour for coilovers & all front arms replaced.
HTH
Mike
What front arms did you replace them with and where did you get them?. Thanks
Sent from my ONEPLUS A6013 using Tapatalk
Posted: Mon Sep 28, 2020 9:52 pm
by mikep99
HTH
Mike
I got the Meyle HD set from https://www.ebay.co.uk/itm/162769367607 ... 2769367607
Mike
Posted: Mon Sep 28, 2020 10:01 pm
by jamiej
Cheers Mike.
