Help with fault code - 01314 - Engine Control Module
Posted: Fri Sep 11, 2020 7:06 pm
Hi all,
It's been a very long time since I have posted, but I am looking for some help.
My car has been sat away for quite some time, used for around 160 miles in the last 12 months. A few weeks ago I took it out for a spin and had engine cut out at high revs, over 6000 rpm. TC and EPC lights came on dash. Engine kept cutting out at high revs a few times when trying before i got home.
Found multiple fault codes with VAG-COM and cleared them.
Drove the car 1 week later and had the same engine cut issue at high revs. ABS fault code and ECM fault code logged with VAG-COM. Cleared the codes again.
Drove the car again today and engine cut again at high revs. ECM fault code logged again.
Fault code is;
1 Fault Found:
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x5C00
Hex Value: 0x4006
Hex Value: 0x0025
Hex Value: 0x01A3
Hex Value: 0x0001
This fault code has logged every time the engine has cut out.
I have searched the web and found a few suggestions. Anyone else have any experience of this and have anything to add.
Thanks in advance, cheeRS,
Simon
Fault code is;
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x5C00
Hex Value: 0x4006
Hex Value: 0x0025
Hex Value: 0x01A3
Hex Value: 0x0001
Simon
