Vert - soft top open/close on key???
Posted: Fri Sep 04, 2020 10:06 am
by Fatneck73
Anyone know if this is an option?
Re: Vert - soft top open/close on key???
Posted: Fri Sep 04, 2020 11:51 am
by Jezza1644
Un-lock the car. Put the key in lock and turn 90 degrees to right which should put all the windows down. When windows are all down turn key to right again which should trigger roof mechanism and put the roof down.
Hope this helps!
Posted: Fri Sep 04, 2020 1:12 pm
by Fatneck73
Brill ta. Will try that later. Can it not be done or programmed to work from the zapper?
Posted: Fri Sep 04, 2020 4:20 pm
by Jezza1644
Good luck! I don't think you can use the zapper to lower/rasise the hood. Be brilliant if you could though!
Posted: Fri Sep 04, 2020 6:31 pm
by sumdy
I can open close the roof from my fob.
Fitted a small module into wiring behind the off side rear seat panel
opens/closes on fob
no need to hold switch if using when driving, just a flick down or up to activate
and i think it raises the speed to 40 mph if used when moving
check out, mods4cars online
Posted: Tue Sep 08, 2020 6:17 pm
by Roj-singh
As sundy says there's a module you can add that gives you that feature otherwise only with key inserted in lock
Posted: Tue Sep 08, 2020 8:55 pm
by Fatneck73
Cheers all
