So just got the car back from Slough Audi and I had approved a repair for some wiring which apparently a mouse or other rodent had started to chew through.
When I got the car home I checked the repair and found it like this.
To say oh not happy is a understatement. Just got off the phone with them and apparently this is how they do their electrical fixes. I asked why they couldn’t supply the original cover like what on the car and I’ve been told that they do not do that sort of trunking.
Question. Would anyone know where I could source this trunking from??
Audi repair
Re: Audi repair
Its a flexible conduit,most electrical wholesaler should be able to help,failing that RS components(pants down though)
Hope this helps
Mav8
Hope this helps
Mav8
RS3- Sepang
Gone
F80-M3
B7-RS4
B5-RS4
Gone
F80-M3
B7-RS4
B5-RS4
Re: Audi repair
Mav8 wrote:Its a flexible conduit,most electrical wholesaler should be able to help,failing that RS components(pants down though)
Hope this helps
Mav8
Thanks mate will have a look
Re: Audi repair
So got the below from Audi. This is the way they do all their electrical repairs.
- Silverfox42
Re: Audi repair
In the RS5 I briefly owned, there was an element of re-wiring that had gone on in a similar fashion, albeit under the engine housing of the B8 engine cover. If nothing else, it looks Amateur on the B7 as its exposed, so quite right to 'reject' it and probably look to escalate to Audi.
2017 RS6 Performance
Previous:
2006 RS4 B7 Cab, 2014 RS4 - Suzuka + a ton of toys, 2011 RS5, spec'd up + ABT exhaust, 2006 B7 RS4 'loon - 5 years of fun! 2006 Aston V8 Vantage, 2006 S4 Cab, 2005 S4 Avant, 2000 TT 225 Cab, 2001 2.5 A4 TDI Quattro, 2000 A4 1.8T Sport, 1996 2.6 80 Cab, 1997 A4 1.8 T Sport
Previous:
Re: Audi repair
I can see why they do it like that - as if tracing an electrical fault the repaired wires are probably the first place to look. That said I would not be happy with that at all !
I would hide it with this - https://www.amazon.co.uk/sourcingmap%C2 ... ive&sr=1-1
Re: Audi repair
Thanks mateMB2 wrote:I can see why they do it like that - as if tracing an electrical fault the repaired wires are probably the first place to look. That said I would not be happy with that at all !
Re: Audi repair
Actually this is even easier as split and can match the OD of the other conduit.
https://www.amazon.co.uk/AUPROTEC-Corru ... 6CG76NXA5C
Users browsing this forum: Google [Bot] and 243 guests
