S5 9x20 fitting advice
Posted: Thu Jan 09, 2020 11:51 pm
by maars
When fitting the OEM S5 9x20ET29 wheels on the B7 RS4 what size spacers are required?
Do you need longer wheel bolts, and if so, what size?
Thank you! :thumbs:
Re: S5 9x20 fitting advice
Posted: Fri Jan 10, 2020 8:31 am
by Daytona
It’s around 4mm to clear the calipers but as hubcentric ones aren’t available that thin I used 8mm with no issues and bought 8mm longer bolts.
Spigots are req too
Posted: Fri Jan 10, 2020 8:34 am
by maars
Thanks Daytona.
Did you use 255 or 265 tyres? Any rubbing issues?
Where did you get the spacers/bolts from?
Posted: Fri Jan 10, 2020 12:36 pm
by Daytona
I’m currently on 255’s but the 265’s I had on before were ok too, suppose it all depends how low the car is.
Pretty sure I got them on eBay, night have been an German seller. I’m thinking of selling the spacers and spigots, if you’re interested give me a pm
Posted: Fri Jan 10, 2020 12:38 pm
by Quango86
I'm interested in the spacers also if you want to drop me a pm I'm on the standard 19s
Posted: Sat Jan 11, 2020 6:13 am
by RS4SA
H&R make hub centric spacers with the correct hub size which allow for the hub size difference between the RS4 and S5. That remove the need for separate spigots!
Posted: Wed Feb 12, 2020 8:41 pm
by Covkiller
You wont' get 4mm hub centric spacers.
Posted: Tue Feb 25, 2020 6:02 pm
by RS4SA
Covkiller wrote:You wont' get 4mm hub centric spacers.
Correct, only from 8mm upwards!
Posted: Tue Feb 25, 2020 7:58 pm
by Rick_RS4
Fitted with no spacers 255 30 tyres and pretty low
Currently forsale too
Posted: Tue Feb 25, 2020 9:55 pm
by DavidRS4
That looks amazing Rick!
Posted: Tue Feb 25, 2020 11:53 pm
by Rick_RS4
:thumbs: thankyou. Changed a bit since then. Wheels, trim, brakes ha ha ,
Posted: Mon Apr 27, 2020 9:46 pm
by Covkiller
Post a recent photo then Rick.
maars did you get your 20's on ?
