S5 9x20 fitting advice
When fitting the OEM S5 9x20ET29 wheels on the B7 RS4 what size spacers are required?
Do you need longer wheel bolts, and if so, what size?
Thank you!
Thank you!
Re: S5 9x20 fitting advice
It’s around 4mm to clear the calipers but as hubcentric ones aren’t available that thin I used 8mm with no issues and bought 8mm longer bolts.
Spigots are req too
Spigots are req too
Thanks Daytona.
Did you use 255 or 265 tyres? Any rubbing issues?
Where did you get the spacers/bolts from?
I’m currently on 255’s but the 265’s I had on before were ok too, suppose it all depends how low the car is.
Pretty sure I got them on eBay, night have been an German seller. I’m thinking of selling the spacers and spigots, if you’re interested give me a pm
I'm interested in the spacers also if you want to drop me a pm I'm on the standard 19s
B7 saloon, koni Shocks and h and r springs, h and r spacers 8mm f+r, milltek non res with valves, milltek d/ps, k and n filter, full mrc carbon clean, mrc stage 2 with l/c and f/s 456bhp 522nm.
H&R make hub centric spacers with the correct hub size which allow for the hub size difference between the RS4 and S5. That remove the need for separate spigots!
You wont' get 4mm hub centric spacers.
Correct, only from 8mm upwards!Covkiller wrote:You wont' get 4mm hub centric spacers.
Fitted with no spacers 255 30 tyres and pretty low
Currently forsale too
That looks amazing Rick!
thankyou. Changed a bit since then. Wheels, trim, brakes ha ha ,
Post a recent photo then Rick.
maars did you get your 20's on ?
Users browsing this forum: Google Adsense [Bot] and 82 guests
