Front brake fitting kit
Is there a source for brembo retaining pins, spring clips and the plates the pads sit on other than TPS/Audi?
Re: Front brake fitting kit
I got mines on ebay for 28 quid a while back
B7 saloon, koni Shocks and h and r springs, h and r spacers 8mm f+r, milltek non res with valves, milltek d/ps, k and n filter, full mrc carbon clean, mrc stage 2 with l/c and f/s 456bhp 522nm.
The plates the pads slide on that are held on with three screws each aren’t available separately, they are stainless so should clean up, one of mine was damaged and I had to pay £100 for one
I’ll have a look, cheers Quango86.
Saw those on the diagrams James1084 and not available separately
Did the screws put up much of a fight and did you manage to reuse them?
I ended up getting the calipers refurbed so screws were OK. Just make sure once you fit the brakes you bed them in properly
I used new screws as the old ones needed torx bits driving in to get them out
Don’t suppose you remember the specs of them or where you got them from?
M5x10 button heads
