Vibration through the steering wheel
Hi can anyone help please
My Audi rs4b7
Had both driveshafts changed as there was a vibration through the steering wheel but it’s still there .
Could anyone recommmend what else I can have done to stop this ie- bushes ? Engine mounts ? Etc
Desperate to fix this .thanks
My Audi rs4b7
Re: Vibration through the steering wheel
Is it there all the time, or just at certain speeds?
Over 60mph
Think it could be the spaces on wheels !!
I take it you've had the wheels balanced. When that's out, I got a vibration at that sort of speed, although it did recede at higher speeds still. Sometimes the weights that fiters use when replacing tyres can become dislodged, so this would be the first (and cheapest) thing to try if you haven't already.
Yes had all wheels checked - ganna have saved taken off and see if it is them and go from there .
Thank u
Thank u
It will most likely be the spacers. Often folk buy the wrong ones. Also ensure you got the correct shaped bolts for the wheels.
If it’s still there after removing the spacers, I’d be looking at the propshaft.
Is the vibration felt just through the steering wheel, or can it be also felt through the drivers seat? Do the headrests vibrate (look through the rear view mirror)? This could help pinpoint whether the problem is at the front or rear.
With spacers, the machining of them is critical. I personally would start with those, as they would for me be the most likely culprit.
Users browsing this forum: No registered users and 104 guests
