How to change brake discs and pads yourself. Not sponsored by Reyland haha
A quick tutorial on how to change front and rear discs inc new pads on a B7. I used Reyland replacement rotors but the process is the same for any pad/disc combo. Hopefully someone will find it useful.
https://youtu.be/mPRTmloXSj0
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Re: How to change brake discs and pads yourself. Not sponsored by Reyland haha
Not fancy using new bolts?
Not thought about it. Don’t think there is much need tho. Where do you buy them anyways?James1984 wrote:Not fancy using new bolts?
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
I measures the standard bolts then bought 20 M6x30 bolts with M6 binx nuts, and bought new caliper bolts to carrier bolts, all from eBay except the carrier bolts which were Porsche ones from ECP
New bolts and bobbins you can get from here:
https://www.mtecbrakes.com/m6-x-30mm-bo ... asher.html
https://www.mtecbrakes.com/2-piece-brak ... bbins.html
Super helpful stuff here, thanks for the the video!! my brakes (Reylands) are being replaced at the garage as we speak, good to know where to get the bolts and bobbins from incase they're all worse for wear!!
I’v stored the link too.
Fantastic video, I've just replaced mine.. but definately one to keep!
Users browsing this forum: Majestic-12 [Bot] and 143 guests
