Exhaust Valve Solenoid Connector
- Bristol RS
- 1st Gear
The metal connector from one of my exhaust solenoids is missing so there is nothing to connect the vacuum hose to! Previous owner has disconnected both so the valves are always open which is great but I would like to reinstate so the valves work.
Has anyone had to replace this if so what have you used any info appreciated!
55 Plate RS4 B7 in Phantom Black
Re: Exhaust Valve Solenoid Connector
I repaired mine but mines a milltek so not sure what a standard valve looks like.
2007 B7 RS4 Saloon, Phantom Black, Forge Oil Cooler Kit, custom home made air feed, H&R Coilovers, H&R anti roll bars, 10mm H&R Spacers, Milltek decat downpipes, Milltek Non Res Valved Exhaust, Reyland Motorsports front & rear discs with Hel braided Hoses, full underbody overhauled inc powdercoated subframes and arms, 034 solid subframe bushes and every joint, arm or bush replaced.
- Bristol RS
- 1st Gear
Hi James the original fitting is very similar to that but looks a bit smaller and is pressed into the solenoid I think unlike yours which is a screw fit. Is that a fitting you have put in yourself? Was looking at doing something similar and tapping a thread into it. Any idea what size that is something like 1/8 or 1/4 bsp?
I tapped it to m6 and used a mountain bike brake fitting, I think tapping to m6 and using a brass gas fitting would have been better and cheaper
- Bristol RS
- 1st Gear
Thanks mate think I have found the same fitting you have on eBay.. why do you think brass would be better? It’s a couple of quid delivered probably get a boxful from China for that! Still only need one and needs must. I can get on with loosening the valves up now make sure they both open OK..
https://rover.ebay.com/rover/0/0/0?mpre ... 2304661549Bristol RS wrote: ↑Tue Sep 10, 2019 10:38 pmThanks mate think I have found the same fitting you have on eBay.. why do you think brass would be better? It’s a couple of quid delivered probably get a boxful from China for that! Still only need one and needs must. I can get on with loosening the valves up now make sure they both open OK..
That’s what I used, I mistakenly tapped mine to m6 and it took ages to find a fitting, there was many more items available in m5 that’s all
- Bristol RS
- 1st Gear
Yeah those. Did some searching after you mentioned M5 and ordered this. Should do the job nicely!
https://www.ebay.co.uk/itm/2-pcs-Straig ... %7Ciid%3A1
Should do the trick, I used a bit of loctite on mine too
Users browsing this forum: No registered users and 268 guests
