Centre box delete
Posted: Mon Sep 02, 2019 7:00 am
by Heardy
Morning all is there any reason these couldn’t be modified to fit the standard system ?
http://vi.raptor.ebaydesc.com/ws/eBayIS ... spheader=1
Is it the fact that the bore size will be the same at the standard exhaust? If so surely i could use some jointing sleeves Or am i just better taking it to an exhaust place
Tia
Re: Centre box delete
Posted: Mon Sep 02, 2019 9:00 am
by marc1
Pretty sure that should work and Milltek are the same size as OE, but maybe give Milltek a call to check. Should sound nice with the centre resonator removed.
Posted: Tue Sep 03, 2019 8:51 am
by MIDZ
Posted: Wed Sep 04, 2019 7:50 pm
by Heardy
Thanks for the link, do you have one of these fitted to yours ?
I’ve come across a scorpion one so i was going to ask if its a direct fit/replacement
Posted: Thu Sep 05, 2019 8:49 am
by MIDZ
I still have OEM system, did some searching and came up with Supersprint manufacturer. Not sure if it's good or bad, although it appears to be direct fit to stock system
Posted: Thu Sep 05, 2019 11:27 am
by coffey555
A good local exhaust fabricator will be able to add straight, x or h pipes to replace the res-centre section for less than the price of the Miltek or Supersprint part, especially once you add shipping and fitting costs.
I went for the straight pipe option, best modification I have done to the car, sounds wonderful with the rear valves always open. No drone, not too loud and has a nice bassy V8 note at low revs and load.
Cold starts are a bit noisy if you still have the cold start function enabled!
Posted: Thu Sep 05, 2019 3:00 pm
by Fatneck73
coffey555 wrote: ↑Thu Sep 05, 2019 11:27 am
Ditto. Love it.
Posted: Sun Nov 17, 2019 9:12 am
by Heardy
Just to update i bit the bullet and went for a Supersprint, great fit and sounds muck better without being too Ott
Posted: Wed Nov 20, 2019 2:18 pm
by FrazerD
Heardy wrote: ↑Sun Nov 17, 2019 9:12 am
You must have more money than sense!
Why did you not go to your local exhaust fabricator and get them to do straight, X or H pipes for a fraction of the price
