Pre cats and clutch pipe
Hi folks,
I am having a bit of a dilemma in my mind and I’m not sure if I’m over thinking things but I’m looking for another perspective.
I’m planning a map and although most of you will say stage 2 MRC live map, I feel I’m not after that and a stage 1 map to change the power delivery is what I want. This is where my dilemma begins, do I gut the pre cats to compliment the map and while the down pipes are out replace the clutch return pipe.
I’m in two minds between doing preventative maintenance and just spending money for the sake of it so will gutting the pre cats compliment a stage 1 map enough to justify the cost of dropping them. If I do, is it worth changing the clutch return pipe while I’m there or does this not prevent enough to warrant the cost.
I know this might sound trivial but I’m just open to another set of eyes.
Re: Pre cats and clutch pipe
Gutting your pre cats will help with flow for a Stage 1 remap and improve power. You could always get cat bypass pipes and keep your cats. This is what I've done. On my first visit to MRC with my Mug Blue RS4, I had bypass pipes fitted, a full carbon clean and the inlet manifold cleared, ported and polished, with the flaps left in tact and no cold air feed, BMC filter and a remap and got 442PS.
Why change the clutch return pipe if you have no problem. I only changed mine for an OEM one when I had my clutch changed.
If I’m going to drop the down pipes I’ll just gut the pre cats and be happy with that. I don’t want to get carried away because I feel like if I do it will be for the wrong reasons. The reason for changing the pipe would be because I’m in there and try to prevent a sticking clutch. I appreciate there are different views on this, hence the perspective.Covkiller wrote: ↑Tue May 07, 2019 9:47 pmGutting your pre cats will help with flow for a Stage 1 remap and improve power. You could always get cat bypass pipes and keep your cats. This is what I've done. On my first visit to MRC with my Mug Blue RS4, I had bypass pipes fitted, a full carbon clean and the inlet manifold cleared, ported and polished, with the flaps left in tact and no cold air feed, BMC filter and a remap and got 442PS.
Would you leave it alone until if or when the clutch caused an issue? Do you think the gains from gutting the pre cats warrants the cost of doing them?
I think you'd be best going stage 2 if you gut the precats as per the MRC website - http://www.mrctuning.com/index.php/audi ... /rs4-b7-2/
Mike
Mike
I’m not going stage 2 though so it comes down to if it warrants gutting them with a stage 1 map or if there’s not much to gain then it’s just money down the drain.mikep99 wrote: ↑Tue May 07, 2019 10:13 pmI think you'd be best going stage 2 if you gut the precats as per the MRC website - http://www.mrctuning.com/index.php/audi ... /rs4-b7-2/
Mike
I wouldn't bother gutting them with a stage 1 tbh.
keep the hardware stock.
Mike
Mike
Thanks for your input. And would you replace the clutch return pipe if there were no symptoms therefore gutting the pre cats would make sense as the downpipes would be off? Or just leave well alone and cross the bridge if or when I get to it?
I can understand your train of thought here but personally, I'd leave the clutch pipe alone if you're not having any problems.
Suppose you could think another step ahead and change the clutch etc as you'd be changing the pipe.... It never ends.
Once the downpipes are out, they should be a lot easier to remove next time. The issues arise with corroded studs that haven't been touched since the car was built.
Mike
Sent from my PRA-LX1 using Tapatalk
Mike
Thanks for you input again, it’s appreciated. I know what you mean about it never ending and that’s why I wanted another perspective. Trying to find the line between preventative maintenance and just spending for the sake of it.mikep99 wrote: ↑Tue May 07, 2019 11:47 pmI can understand your train of thought here but personally, I'd leave the clutch pipe alone if you're not having any problems.
Mike
Users browsing this forum: No registered users and 554 guests
