AUTODOC has a a 25% off just now and I'm going to be changing the suspension soon. Has anyone used the meyle HD arms at they any good? Also my be a stupid question but how many of each arms do people change. Top 2 bottom 2 and drop links? I'm also going to change the strut tops try and tighten it right up.
Thanks John
Front arms
Front arms
B7 saloon, koni Shocks and h and r springs, h and r spacers 8mm f+r, milltek non res with valves, milltek d/ps, k and n filter, full mrc carbon clean, mrc stage 2 with l/c and f/s 456bhp 522nm.
Re: Front arms
I replaced the lower front arms (4 in total) and drop links with Meyle hd ones about a year ago. No issues so far. Top arms had been replaced by Audi so didn't bother to replace them at the time .
Re: Front arms
Each ment per side. Was going to just freshen it all up while I was there.
Re: Front arms
I had everything but the track rod ends replaced with the Meyle kit and all is well. On the plus side lifetime warranty with this kit!
2006 B7 RS4 Avant Sprint Blue & Black Optics
2000 Avus Silver B5 RS4 - Gone
Re: Front arms
Where did you purchase it from?
Re: Front arms
https://www.motorpartsni.co.uk/
There website isn't the best but if you give them a ring they should be able to sort you out.
They won't be difficult to find with the usual auto stockists demontweeks etc
Re: Front arms
re meyle hd-excellent quality
most important thing is when tightening the bolts do it with suspension loaded-weight of car on it
otherwise they get torn apart
and good luck with the upper pinch bolts-they can be a pita
Re: Front arms
And use a torque wrench
Otherwise you may snap the pinch joint(s)
Not sure if you can get this in the UK, but it works great
Give all threaded joints a shot and let it set for 5-10 minutes
Kroil http://www.kanolabs.com/
Make sure to get it off before reassembly
Brake cleaner works
Brake cleaner works
Users browsing this forum: OPOGTS and 521 guests
