Rear anti roll bar SS+ vs H&R
Is there any benifit going for h&r? I have SS+ at the moment
2007 B7 RS4 Saloon, Phantom Black, Forge Oil Cooler Kit, custom home made air feed, H&R Coilovers, H&R anti roll bars, 10mm H&R Spacers, Milltek decat downpipes, Milltek Non Res Valved Exhaust, Reyland Motorsports front & rear discs with Hel braided Hoses, full underbody overhauled inc powdercoated subframes and arms, 034 solid subframe bushes and every joint, arm or bush replaced.
Re: Rear anti roll bar SS+ vs H&R
Yes. Much stiffer. Car becomes much more neutral and flat in cornering.
Thanks, i wasnt sure whether upgrading an already upgraded bar would be worth it, dont suppose you know whether SS+ anti roll bar clamps can be re used or if they come with the kit?
You just need the H&R kit no extra parts required. I did the thicker front ARB from H&R at the same time.
- 2nd Gear
Usually the new bars come with their own rubbers as the diameter of the bar is bigger , the mounting brackets remain standard .
Does the increase in arb size affect general comfort at all?
Yes, it makes the low speed ride quality harsh. There are 2 settings on the ARB's so you could make it softer.
Misano Red RS4 B7 Avant
Hard to say for me - I did coilovers at the same time. The car feels like it rides much better, but I'm used to performance cars - so depends on what you feel is 'good'.
Problem is audi made two brackets for SS and SS+ so if i do order the bars will have to see if mine fitShockerboy wrote: ↑Sun Mar 31, 2019 7:31 pmUsually the new bars come with their own rubbers as the diameter of the bar is bigger , the mounting brackets remain standard .
- 2nd Gear
jamesbaby , the thicker A R B shouldnt affect comfort at ALL , The purpose of the anti roll bar is to increase affective spring rates ONLY in cornering to limit body roll .
Ok thanks for your input. I was thinking of going to the SS+ Arb.
The DRC on my Avant is working fine but to me the rear end feels a little harsh. Springs are all checked and ok. So don’t want to do anything that would make it feel worse.
Ordered myself a set of h&r bars and the SS+ brackets don’t fit which is a pain as I bought new ones, so I either buy new brackets and use the h&r bushes or buy 22mm bushes for the standard brackets
Do you have a SS+ ARB for sale? If so I’d like to buy it from you.
Springs too if you have them.
Users browsing this forum: MTBear and 487 guests
