Engine Undertray - again!
Posted: Mon Mar 04, 2019 6:32 pm
by delroyx
I have tried the search and can't find the specific answer to my query.
I need a new engine undertray - but local TPS say there are now near as dammit £400 (inc VAT). Even with some discount the best I could get it down to was still £300 odd. It was described as 'heavy duty' so I'm guessing it's been revised at some point - part number now 8E0863821AT which I guess supersedes the one I had which ended AP. (Funny how old threads suggest they were “only” £180 a few years ago!)
Anyway, I know many will say get one fabricated like Faisal but that is even bigger bucks.
I'm wondering will a standard A4/S4 one fit - now I understand they won't have the vents for brakes etc but I'm willing to cut some in if needed as I have the remains of my old one I can use to offer it up?
I just wondered if the dimensions are the same?? From the research I've done there is some suggestion the RS4's undertray is wider than a standard one.
If a standard one does fit, are they all the same – ie one from a petrol/diesel
Any help appreciated.
Re: Engine Undertray - again!
Posted: Mon Mar 04, 2019 6:53 pm
by mikep99
found this from last year:
https://www.audi-sport.net/xf/support-t ... ssage-9198
might be worthwhile dropping Tom at Crewe Audi a message to see what he can get hold of..
EDIT - yep, the 'T' version supersedes the 'S' version:
https://audi.7zap.com/en/rdw/audi+rs4+a ... -863025/#1
Mike
Posted: Mon Mar 04, 2019 6:57 pm
by FrazerD
If you want one soon I wouldn’t bother. I’m still waiting for him to reply about buying adaptors for my windscreen washers that I have since bought from elsewhere and fitted.
Posted: Mon Mar 04, 2019 6:59 pm
by delroyx
Thanks email sent. Fingerscrossed. Cheers
Posted: Tue Mar 05, 2019 12:28 pm
by delroyx
Tom @ Crewe Audi has replied
"RRP is £399.23 the best i can do is £360.00 postage £50.00"
Does anyone know if a standard A4/S4 one will fit?
Posted: Tue Mar 05, 2019 5:22 pm
by Kenny147
They won’t and besides they won’t have the mounting points for the brake cooling ducts.
Posted: Tue Mar 05, 2019 6:01 pm
by delroyx
Are they different dimensions then?
I was thinking of some how cutting the old mounting points off the remains of my old one & somehow cutting/bonding them to a standard one.
Looks like I might just bite the bullet
Posted: Wed Mar 06, 2019 3:37 am
by Kenny147
I’m pretty sure they're not only different dimensions but the mounting points are all different. It’ll look like a dogs breakfast if you try to “adapt” a non-RS4 undertray to do the job. Not that you’d ever see it.
If it makes you feel any better, the updated part is still more expensive in the US, than it is the UK.
You can still get the AS part but it’s noticeably thinner than the AT part, although it is far cheaper.
Posted: Wed Mar 06, 2019 10:35 am
by delroyx
Brilliant thanks that answers my question.
New one it is then.
Posted: Wed Mar 06, 2019 2:07 pm
by mikep99
Or perhaps try some of the ones being broken on ebay if you're not happy with the price?
Mike
Sent from my PRA-LX1 using Tapatalk
Posted: Wed Mar 06, 2019 3:13 pm
by Ranger Rico
delroyx wrote: ↑Wed Mar 06, 2019 10:35 am
New one it is then.
I need a new one too, tell us how you get on bud, im interested to know how different the updated tray is as the original was a disgrace.
Posted: Wed Mar 06, 2019 5:50 pm
by coffey555
Get the workshop guys to make you up a new one Rico!
Does not need to be as strong what with the saloon's being slower
Posted: Fri Mar 29, 2019 5:15 pm
by delroyx
Quick update & a few things which may help others.
New undertray is finally on. Can't believe how much of the old one disappeared!
Anyway, had some 'fun' with the dzus(?) bolts. I had some cheap ones from ebay but they were rubbish. They are so soft and the ends got chewed by the clips so didn't hold.
The one on the left is OEM the right is ebay rubbish.
TPS charge RRP of nearly £4 each for these.
Also I found a flat head screwdriver didn't work so bought a tool specially for it - should make removing much easier.
Also found I needed a small bit of trim at the leading edge of the wheel arch which got a bit mangled when the tray came off. All ordered so 99% there with it.
Part numbers which may help others:
Undertray
8E0863821 AT
Air ducts for brakes - I managed to fix mine
8E0863149
8E0863150
Mud guard trim
8E0853887F
Bolts
8D0805121
Hope this helps someone
Posted: Fri Mar 29, 2019 5:17 pm
by delroyx
Can't seem to add the photos.
