EPC / ESP light
MrRSB7
EPC / ESP light
Post by MrRSB7 » Sat Feb 02, 2019 10:44 am
After owning my 2006 RS4 with 50k on it for 6 months , not a hint of a problem, car is a dream and definitely a keeper.
Started her up this morning and found the EPC/ESP Lights on, drives perfectly , no noises etc?
Any suggestions on what this could be?
Many thanks
MrRSB7
Re: EPC / ESP light
Post by MrRSB7 » Sat Feb 02, 2019 10:46 am
andyg72
Re: EPC / ESP light
Post by andyg72 » Sat Feb 02, 2019 10:51 am
I once had this light show my fault was steering angle sensor
But it could be one of many sensors related to the stability program of the car
Needs scanning
MrRSB7
Re: EPC / ESP light
Post by MrRSB7 » Sat Feb 02, 2019 10:54 am
Is this an Audi diagnostic job?
My local is Audi cribs causeway ( Bristol)
andyg72
Re: EPC / ESP light
Post by andyg72 » Sat Feb 02, 2019 10:56 am
MrRSB7 wrote:Is this an Audi diagnostic job?
No most mechanics will have the correct diagnostic tools
Possibly a member your way could help ?
AA_954
Re: EPC / ESP light
Post by AA_954 » Sat Feb 02, 2019 6:56 pm
MrRSB7 wrote:After owning my 2006 RS4 with 50k on it for 6 months , not a hint of a problem, car is a dream and definitely a keeper.
Many thanks
I got this also this week, did you run a diagnostic tool to see what code you have? Surprised it drives perfectly, my power got limited to 3k revs, in the end it came up after driving through heavy rain, after a while it went away, have to check a few things around the ECU to see what might have got wet. For reference the codes that I got were 2128 and 2138...
Sent from my iPhone using Tapatalk Pro
MrRSB7
Re: EPC / ESP light
Post by MrRSB7 » Sat Feb 02, 2019 7:05 pm
No , I have no diagnostic tool, I’ll try and find a local indi to plug her up
AA_954
Re: EPC / ESP light
Post by AA_954 » Sat Feb 02, 2019 7:08 pm
MrRSB7 wrote:No , I have no diagnostic tool, I’ll try and find a local indi to plug her up
Ok, worth investing in a cheap one, I bought a 20$ one at a local autostore. Also ODB11 is a good tool to have if you have an android phone
Covkiller
Re: EPC / ESP light
Post by Covkiller » Sun Feb 03, 2019 11:05 am
This sounds like a throttle body problem. I had exactly the same issue. The car drives perfectly, then it goes into limp mode. You switch the car off and its ok for a while then the issue repeats. My car had done about 70k at the time. A new throttle body is about £1300 fitted Audi.
RS4 B7, Mugello Blue, K&W V3 & HR ARBs, set up by Centre Gravity, Milltek Valved Non Res & cat bypass pipes, BMC air filter, braided hoses, DOT 5.1, Terraclean, MRC Full Carbon Clean, MRC remap 448PS 477NM, 20" S7 alloys with 4mm spacers & Hawke spigots 66.6 > 57.1, AP Racing front discs.
AA_954
Re: EPC / ESP light
Post by AA_954 » Sun Feb 03, 2019 5:36 pm
Covkiller wrote:This sounds like a throttle body problem. I had exactly the same issue. The car drives perfectly, then it goes into limp mode. You switch the car off and its ok for a while then the issue repeats. My car had done about 70k at the time. A new throttle body is about £1300 fitted Audi.
Crazy expensive when its the same throtthe body as the Corvette C6 Z06, you can buy those too off Rockauto for half or less than what the audi stamped (exact part number) one costs...
Covkiller
Re: EPC / ESP light
Post by Covkiller » Sun Feb 03, 2019 6:13 pm
Thats good news
Users browsing this forum: Baidu [Spider] and 74 guests
