Squeaky Suspension
rs4jas
Squeaky Suspension
Post by rs4jas » Sat Jan 12, 2019 5:26 pm
Hi I have a RS4 B7. I’ve recently changed out the DRC system for a bilstein B14 coilover kit. New top mounts. All upper front arms and drivers front lower rear arm. Also polybushed anti roll bar bushes. There’s a REALLY annoying squeak coming from the drivers front and it’s doing my head in. It sounds like a squirrel is in my wing. It happens constantly when driving no matter what road surface.
Any ideas? Don’t want I change anything just to guess.
alex760
Re: Squeaky Suspension
Post by alex760 » Sat Jan 12, 2019 11:16 pm
I've had squeaks from polybushes in the past, especially powerflex ones. Could be those?
Seattle-squash
Squeaky Suspension
Post by Seattle-squash » Sat Jan 12, 2019 11:46 pm
rs4jas wrote:Hi I have a RS4 B7. I’ve recently changed out the DRC system for a bilstein B14 coilover kit. New top mounts. All upper front arms and drivers front lower rear arm. Also polybushed anti roll bar bushes. There’s a REALLY annoying squeak coming from the drivers front and it’s doing my head in. It sounds like a squirrel is in my wing. It happens constantly when driving no matter what road surface.
Unfortunately the coil-over systems are often a bit noisy, especially at low speed over speed bumps etc... and got some light creaking myself with my B16. I spent lots of time trying to silence it 100% but eventually gave up with mostly all new parts. I think often it’s the coil springs binding against themselves which is tough to fix.
rs4jas
Post by rs4jas » Sun Jan 13, 2019 8:50 am
Ohhh ok. Just wondered if something was wrong as it didn’t squeak at 1st but after a couple of weeks it started. What if I lifted the front up? Have you tried that? Does that quieten it down?
Covkiller
Post by Covkiller » Sun Jan 13, 2019 10:07 am
You can lubricate your springs and top mounts, you could use sillycunt lubricant:
https://www.amazon.co.uk/WD40-Performan ... B00KPUBRJ8
RS4 B7, Mugello Blue, K&W V3 & HR ARBs, set up by Centre Gravity, Milltek Valved Non Res & cat bypass pipes, BMC air filter, braided hoses, DOT 5.1, Terraclean, MRC Full Carbon Clean, MRC remap 448PS 477NM, 20" S7 alloys with 4mm spacers & Hawke spigots 66.6 > 57.1, AP Racing front discs.
rs4jas
Post by rs4jas » Sun Jan 13, 2019 10:19 am
Awesome I’ll give anything a try.
jamiej
Post by jamiej » Sun Jan 13, 2019 10:40 am
Don't the B16s have a different piston protector, like a corrugated sleeve, whereas the B14s have a straight sleeve, could this be causing the sqeak?
Sent from my ONEPLUS A6013 using Tapatalk
Current
'07 - Audi RS4 Avant Daytona Grey
'02 - Audi 8L A3 1.9 TDI (PD)
Gone
'03 Subaru Impreza WRX STI
'96 VW Golf VR6
'91 Toyota MR2 N/A
'90 Peugeot 205 GTI 1.9
'90 VW Mk2 Golf GTI 8V
MrRSB7
Post by MrRSB7 » Wed Jan 16, 2019 11:17 pm
C’mon now, no need for squirrel talk 🐿
coombsie66
Post by coombsie66 » Fri Jan 18, 2019 9:57 am
I have exactly the same from my Bilsteins, thought it was the arm bushes being under torsion from tightening the bolts with the arms in droop - so re-did those with the arms in the correct position - no change.
I think it is damper shaft dust cover/sleeve rubbing on the inside of the coils as the squeaking is far less in the wet and seemed to go away for a while after lubricating the sleeve.
Pretty pathetic fault from a manufacturer like Bilstein to be honest.
Wondering if some zip ties around the sock to pull it in a touch might help?
marc1
Post by marc1 » Fri Jan 18, 2019 2:51 pm
There is a known issue with B14’s squeaking from memory. If you google or search this forum with B14 included in the key words. Doesn’t apply to B16’s from what I remember.
Users browsing this forum: cherub72, DoubleL, monkeychap, neil_f, PinkPineapple44, Quango86 and 68 guests
