New front discs
Fatneck73
New front discs
Post by Fatneck73 » Sat Dec 29, 2018 10:06 pm
Gonna need some when next change pads so started looking.
Any suggestions re what to go for and from whom???
Can see following:
cartech1: £452 for both and ‘2 parts’ which I assume means rotor AND bell (think that’s the relight terminology?).
https://www.cartech-one.co.uk/en/produc ... nt/v-18524
Reyland: £345 but just rotors.
https://www.ebay.co.uk/itm/Audi-RS4-B7- ... 1438.l2649
JHM: $595 for rotors only.
https://jhmotorsports.com/front-rotor-r ... 7-rs4.html
Cheers,
James1984
Re: New front discs
Post by James1984 » Sat Dec 29, 2018 10:58 pm
I went reyland, bought 20 m6x30mm 6mm bolts for £2.50 and 20 m6 binx nuts for £7 not yet used so cant comment on that
AA_954
New front discs
Post by AA_954 » Sun Dec 30, 2018 12:06 am
Fatneck73 wrote:Gonna need some when next change pads so started looking.
Can see following:
Cheers,
Depends on how much you want to spend, a few of us stateside are using Giro and others Stoptech, not cheap alternatives but definately good quality
Sent from my iPhone using Tapatalk Pro
marc1
Re: New front discs
Post by marc1 » Sun Dec 30, 2018 12:23 am
That’s a good price for the fronts from Cartech1. Wonder if they do the rears too. I remember when you were send to regularly get both front and rears for c.£400 a set. Seem closer to £600 generally nowadays.
The Reylands are a good option. They only do J hook and slotted designs as say the drilled ones clog and crack, which can be true. They also do a two piece rear which is about £550 from memory, then just get new discs from then on and use the existing bells. They would do you a bell for the fronts two, but they’d be a similar cost (c.£200).
Maybe we could get a group but going on at Reylands?!
Fatneck73
Re: New front discs
Post by Fatneck73 » Sun Dec 30, 2018 8:22 am
I don’t wanna spend more than needed - aka I don’t need to buy a brand name...but I do wanna buy whatever is recommended for the roads.
Any more votes for Cartech1?
Fatneck73
Re: New front discs
Post by Fatneck73 » Sun Dec 30, 2018 8:37 am
PS...any suggestions on pads?
marc1
Re: New front discs
Post by marc1 » Sun Dec 30, 2018 11:09 am
If your rears are in good shape, then the Cartech1 are the cheapest option. If the rears will need doing at some point in the near future the Reylands might be better.
DS2500 pads are a favoured option for the road. I’d also do stainless lines and updated fluid at the same time, which will probably add £100ish to the bill, but the car will break a lot better.
Covkiller
Re: New front discs
Post by Covkiller » Sun Dec 30, 2018 12:44 pm
As a Cov lad I use AP disks. They're night and day above OEM and as marc1 says with DS2500's you stop on a six pence.
https://www.apracing.com/product_detail ... z14sd.aspx
You need to buy them from a 3rd party, but if you call them they will tell you your nearest stockist. Be aware there is a lead-time of 4 ish weeks sometimes. The bells are re-usable. The cost is compatible with OEM.
RS4 B7, Mugello Blue, K&W V3 & HR ARBs, set up by Centre Gravity, Milltek Valved Non Res & cat bypass pipes, BMC air filter, braided hoses, DOT 5.1, Terraclean, MRC Full Carbon Clean, MRC remap 448PS 477NM, 20" S7 alloys with 4mm spacers & Hawke spigots 66.6 > 57.1, AP Racing front discs.
marc1
Re: New front discs
Post by marc1 » Sun Dec 30, 2018 2:05 pm
^ Cov do you use the AP on the rear too? Also what rear pads? I hear there isn’t a DS2500 option for the B7 rears, but I’m sure there must be?
Covkiller
Re: New front discs
Post by Covkiller » Sun Dec 30, 2018 4:31 pm
I use rear OEM discs with Pagid pads. When they'e worn out I'll fit Ferodo DS2500 FCP1655H rears.
marc1
Re: New front discs
Post by marc1 » Sun Dec 30, 2018 4:43 pm
:thumbs:
Fatneck73
Re: New front discs
Post by Fatneck73 » Sun Dec 30, 2018 7:32 pm
So upon checking, it looks like rears are ok so just front rotors/discs needed (and pads, fluid and pipes).
So any reason not to go for Reyland front rotors/discs plus DS2500, 5.1 and braided lines??? Sound good.
marc1
Re: New front discs
Post by marc1 » Sun Dec 30, 2018 8:54 pm
No reason not to. Get them bought. :thumb:
James1984
Re: New front discs
Post by James1984 » Sun Dec 30, 2018 10:57 pm
I just like the look of the reylands 😂
Users browsing this forum: darkwolfe, Google [Bot], tommchowat and 77 guests
