Engine hunting on cold start
Posted: Thu Dec 06, 2018 10:55 pm
by demon8991
Hello all,
Very new owner here so just getting used to everything however I have noticed the engine hunting for around 60 seconds on cold start almost gives a kangaroo when driving at steady revs in gear two.
Previous owner said it did this on occasion.
Any ideas what this might be?
Re: Engine hunting on cold start
Posted: Fri Dec 07, 2018 11:38 am
by 12th
If it goes away when the engine is warm, it could be one of the two fuel pumps or possibly the flaps in the inlet manifold. Had something similar (but not as bad) and it was the former.
Posted: Sun Dec 16, 2018 9:44 pm
by Mark Park
I have the same problem to a tea, audi said it needs a new clutch when i spoke to them. Just been a local garage and they said it is the slave cylinder on the clutch. I have also the problem that in 1st gear when its cold its a little stiff to get in. 2nd gear you have to be high revs thrashing it or in low revs from 1st and change realy gentle
Posted: Mon Dec 17, 2018 3:52 am
by demon8991
Thanks for your reply Mark.
Do you intend on fixing the issue?
Posted: Wed Jan 30, 2019 10:14 pm
by markcookie7
Try cleaning maf sensor .
Sent from my F3211 using Tapatalk
