JC WeldFab exhaust track day noise?
Has anybody with a JC WeldFab full exhaust been to a track day? If so, were you under the noise limit with the valves open? Really want to go to for a track day but don't want to get refused because its too loud.
Re: JC WeldFab exhaust track day noise?
@faisalCalUmB7 wrote:Has anybody with a JC WeldFab full exhaust been to a track day? If so, were you under the noise limit with the valves open? Really want to go to for a track day but don't want to get refused because its too loud.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Valves open? No <beep> chance!
2007 RS4 B7 Avant
You’ll be black flagged before you even get to the circuit.
Yeah I had a feeling this would be the case, guess I need to get a forza valve controller then? @faisal which model did you get?
Yep - the exhaust controller will sort that out - you’ll be fine with the valves closed.CalUmB7 wrote:Yeah I had a feeling this would be the case, guess I need to get a forza valve controller then? @faisal which model did you get?
It’s the E3 model you need - replaces the B3A I have.
http://www.forzacomponenti.com/controller_e3.html
2007 RS4 B7 Avant
I made it 2-3 laps as they got confused who was making all the noise and pulled Andy G into the pits instead of me!marc1 wrote:You’ll be black flagged before you even get to the circuit.
2007 RS4 B7 Avant
Awesome thanks for the info. Is it a DIY installation or am I better getting some help?FaisalJ wrote: ↑Sat Dec 01, 2018 11:18 amYep - the exhaust controller will sort that out - you’ll be fine with the valves closed.CalUmB7 wrote:Yeah I had a feeling this would be the case, guess I need to get a forza valve controller then? @faisal which model did you get?
Yep easy DIY - even I managed it!CalUmB7 wrote:Awesome thanks for the info. Is it a DIY installation or am I better getting some help?FaisalJ wrote: ↑Sat Dec 01, 2018 11:18 amYep - the exhaust controller will sort that out - you’ll be fine with the valves closed.CalUmB7 wrote:Yeah I had a feeling this would be the case, guess I need to get a forza valve controller then? @faisal which model did you get?
2007 RS4 B7 Avant
You'll be fine at the Nurburgring. I have a straight through non res Milltek with only back boxes and have no problem. But have not a chance on any UK tracks.
Thanks for the info. I notice on Forza's website they sell an adapter for Audi, presumably I'll need this too or is straight fit?FaisalJ wrote: ↑Sun Dec 02, 2018 4:44 pmYep easy DIY - even I managed it!CalUmB7 wrote:Awesome thanks for the info. Is it a DIY installation or am I better getting some help?FaisalJ wrote: ↑Sat Dec 01, 2018 11:18 am
Users browsing this forum: delroyx and 498 guests
