Hi.... brake fault light???
Hello..... discs and pads look like they have 500 miles on them if that!
That’s for the front and rear
Brake fluid level looks fine, yet this warning pops up every now and again..... any suggestions??
And the same with the bonnet sensor , normally comes on when I reach the 100mph mark.... slightly unnerving thinking about the bonnet flying up at high speeds
2006 2-tone merlin purple , decat delete, res delete, x-pipe and rear back box delete......rs5 alloys.. silver brake callipers
Re: Hi.... brake fault light???
Not sure what you are saying, if the pads only have 500 miles left in then you would see that warning ? Change them.MrRSB7 wrote:
Not sure about the bonnet, faulty sensor maybe?
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
I think he is saying that they look like they ha e only done 500 miles. If so then check the wiring to the brake pad sensor, sounds like it has a dodgy connection or the wire is on its way out.
Indeed!!!
My fault!
Brakes look like they’ve only done done 500 miles
Very new
Will check wiring etc
My fault!
Very new
Remove the connection, spray some terminal cleaner in there and reconnect.MrRSB7 wrote:Indeed!!!
My fault!
Very new
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
If your sensor terminals corroded as mine were, I got some emery paper cut it into a narrow strip and rubbed the female terminals. I had to do this periodically which annoyed me. So, I went to Audi and they do a repair kit which is easily fitted if you can solder and use shrink wrap.
Users browsing this forum: No registered users and 255 guests
