Standard ride height
Posted: Sat Nov 17, 2018 4:43 pm
by James1984
I have my car up on axle stands and now need to change the suspension which was originally unplanned, can anyone help with some dimensions from the arches to the top of a 19” rim or center of the wheel ideally ss+? Im fitting coilovers so i know it will still be lower on the front
But would like to pre torque the control arms. Thanks
Re: Standard ride height
Posted: Fri Dec 07, 2018 12:06 am
by James1984
Anyone ever measures the ride height of a car on h&r springs? Want to be at a similar height with mine, maybe 10mm lower
Posted: Sun Dec 09, 2018 7:58 pm
by Shockerboy
H&R are 20 /25 mm, so 10 mm more than that will be the highest setting for the coil over kit . Coil over units normally do 30 to 50 mm . 50 is too low on the RS4 in my opinion . the body of the shock in a coil over kit is often shorter than a standard shock . thus is good for comfort ,but risky for tyres hitting the fenders depending on the wheel and tyres fitted ( as well as spacers )
Posted: Sun Dec 09, 2018 10:07 pm
by James1984
I was hoping someone had dimensions from the arch to rim or center of wheel etc so i could tighten the control arms to where i want the car to sit around -30mm on the front which is the minimum on the kit and around its standard height (SS+) at the rear but maybe 5mm lower, i have the suspension fitted without scocks so i could jack the hubs up, totque the upper control arms and then fit the coilovers after and then replicate my chosen height, i could really do without having to put it onto its wheels and on the floor.
Posted: Sun Dec 09, 2018 10:49 pm
by super7
I put a set of SS+ springs on mine. If it’s useful I could take measurements for you?
Posted: Sun Dec 09, 2018 11:29 pm
by James1984
super7 wrote: ↑Sun Dec 09, 2018 10:49 pm
If you wouldnt mind that would be great, could i be cheeky and ask for the front too haha
Posted: Mon Dec 10, 2018 9:19 am
by Covkiller
James1984 rule No1 please as things progress
Posted: Mon Dec 10, 2018 12:56 pm
by James1984
Covkiller wrote: ↑Mon Dec 10, 2018 9:19 am
Im going to have to get the big camera out and start a progress thread, i only took it off the road to fit my new discs and paint the calipers and its starting to get out of hand.
Posted: Wed Dec 12, 2018 6:34 pm
by super7
James1984 wrote: ↑Sun Dec 09, 2018 11:29 pm
Here’s some pics with a tape measure (top is front, bottom is back):
Posted: Wed Dec 12, 2018 6:36 pm
by super7
Front might have been sitting a touch high. I have pebble drive and it may have dug in a bit at the back lifting the front.
Posted: Thu Dec 13, 2018 3:26 pm
by James1984
super7 wrote: ↑Wed Dec 12, 2018 6:36 pm
Thanks for that! Yeah the front does look a bit high doesn’t it, i have set mine at 75mm from arch to rim which doesn’t look too bad, wish id measured it before i took it off the road.
Posted: Thu Dec 13, 2018 6:46 pm
by GaryA
Might be a bit late but if it helps I'm on H&R springs with DRC
Rim to arch on Front is 75mm with 60/65mm on Rears
Personally I'd normally prefer to see it level but happy with the way it sits on the springs
Posted: Thu Dec 13, 2018 9:49 pm
by James1984
GaryA wrote: ↑Thu Dec 13, 2018 6:46 pm
Thanks thats great, i didnt want mine much lower than h&r springs would give but i decided to junk the drc as the lines weren’t great and i had a broken spring and i got a decent deal on h&r coulovers.
