Page 1 of 2
Rear Callipers upgrade
Posted: Mon Nov 12, 2018 2:38 pm
by andyg72
I’m looking to replace my rear callipers for some tarox
I’ve had a good look around but cannot find anyone that has done this ?
Do tarox even supply a calliper for the rear
Main reason mine are showing there age plus I’ve tarox up front so would like them to match
I have emailed tarox twice now with no reply
Any suggestions or links would be appreciated
Re: Rear Callipers upgrade
Posted: Mon Nov 12, 2018 4:16 pm
by andyg72
Reply from tarox
Hi Andy
The issue with the rear set up is the integral handbrake caliper. Systems can be built but they are not off the shelf. Some of dealers build kit by retaining the OE caliper for the handbrake and then building a bracket to mount our calipers.
If you are happy for someone to start a project like this then I would recommend. TSR, VRT or Retro Resus as they all have experience with custom rear kits.
Posted: Mon Nov 12, 2018 7:21 pm
by MikeFish
So you going for it then?
Didn't Jonytek do a custom ceramic rear setup with seperate handbrake caliper? Where is he? Haven't seen him on here or insta for a while!
Posted: Mon Nov 12, 2018 7:29 pm
by Surrey Sam
Posted: Mon Nov 12, 2018 8:30 pm
by andyg72
MikeFish wrote:So you going for it then?
Yes mike it’s always bugged me on my last one with ceramics and steel miss match now on the new one
I’ve the discs to match but the rear callipers are showing there age so I’m looking to swap them
Posted: Mon Nov 12, 2018 8:31 pm
by andyg72
Thanks Sam I’ll look into that option
Also the r8 rears but I’ll have to get the colour matched to my fronts
Posted: Mon Nov 12, 2018 8:35 pm
by andyg72
Someone has mentioned jony tec before I’ll try contact him for some advice
Posted: Mon Nov 12, 2018 9:47 pm
by marc1
I wonder if
https://www.tomwrigleyperformance.com/ could help. Not sure if it’s only AP they do though.
Posted: Mon Nov 12, 2018 11:30 pm
by Jon_J
andyg72 wrote:Someone has mentioned jony tec before I’ll try contact him for some advice
Jonys RS4 Project
https://r.tapatalk.com/shareLink?share_ ... are_type=t
Posted: Mon Nov 12, 2018 11:32 pm
by andyg72
Seems all modifications on the rears require separate handbrake & messes with the brake bias if this is the case I’ll not Pursue & most likely replace with stock callipers but colour match to the fronts either anodise or powder coat
Posted: Mon Nov 12, 2018 11:34 pm
by Jon_J
andyg72 wrote:Seems all modifications on the rears require separate handbrake & messes with the brake bias if this is the case I’ll not Pursue & most likely replace with stock callipers but colour match to the fronts either anodise or powder coat
Definitely the easiest job. Get them re powder coated and refurb them whilst they are out.
I did the refurb myself and just had them powder coated by someone else.
Posted: Mon Nov 12, 2018 11:37 pm
by andyg72
Jon_J wrote:andyg72 wrote:Seems all modifications on the rears require separate handbrake & messes with the brake bias if this is the case I’ll not Pursue & most likely replace with stock callipers but colour match to the fronts either anodise or powder coat
Jon do you know if they Can be anodised ?
Iill buy new so straight swap once colour has been sorted
Posted: Mon Nov 12, 2018 11:39 pm
by Jon_J
andyg72 wrote:Jon_J wrote:andyg72 wrote:Seems all modifications on the rears require separate handbrake & messes with the brake bias if this is the case I’ll not Pursue & most likely replace with stock callipers but colour match to the fronts either anodise or powder coat
They are aluminium so don’t see why not?
Posted: Tue Nov 13, 2018 12:18 am
by andyg72
I wasn’t sure if they were alloy now I know
Posted: Tue Nov 13, 2018 7:50 am
by Jon_J
andyg72 wrote:I wasn’t sure if they were alloy now I know
Definitely alloy
