Hi,
I’ve just bought my first B7 RS4,had it one month and I love it
How can I tell if the car has the standard DRC suspension , and how can I tell if it’s been lowered?
Many thanks
B7 RS4 lowered?
B7 RS4 lowered?
2006 2-tone merlin purple , decat delete, res delete, x-pipe and rear back box delete......rs5 alloys.. silver brake callipers
Re: B7 RS4 lowered?
If it has the standard DRC the shocks will be connected via hydraulic pipes. If you can park a car in the gap between the top of the wheel and the arch it’s on standard springs.MrRSB7 wrote:Hi,
Many thanks
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
- Trader (Expired)
Re: B7 RS4 lowered?
Hi there . the Hydraulic pipes are indeed connected to the shocks from the body coupled to a charging valve , I think the easy way is to look at the colour of the shock . most after market shockers ( performance ones ) arent black . the standard shocks will also have Audi part numbers if you can get into the wheel arch to look . The standard car does have a slightly bigger front wheel arch gap than the rear this is purposely done to allow clear movement of the front steering wheels . the gap is usually about 50 to 60 mm in front , or say 3 fingers . Quality lowering kits will lower no more than 20 to 25 ,mm . if it. s really low it will have a coil over kit which you will easily recognise as the ride will be quite a bit firmer .
Re: B7 RS4 lowered?
Your car is too high if you can get your hand in between the top of the tyre and wing
Users browsing this forum: No registered users and 240 guests
